Just received a used Oil Press guage and it reads 12psi?? problem??
Well I bought these guages used. BF series. I have seen other people post about the guages not reading 0, but I dont know if I should worry or not.
The guage reads a good amount above zero and nothing is plugged into it. I know others have take their guages apart and crimped the little tank, but I rather not do that if I dont have to.
I wont be able to afford installing these for a little while so I need to know if I should worry, or if the guage will zero out once it is installed?
Anyone else run into this? It's reading at 12psi.....
Thanks in advance,
Ken
Thanks in advance,
Ken
This is a DEFI BF oil pressure guage that reads 12 psi with nothing hooked up.....trying to see if there is something wrong, or somehting that will correct itself when powered up.
