Is the RnR HKS Carbon Ti authentic?
Old Nov 10, 2006 | 07:43 PM
Erik@MIL.SPEC's Avatar
The inlet to the HKS muffler is approximately 3 inches, however, the inside doesn't pass the Al "Coke can" test. I would point out that when my car was dynoed, the numbers didn't seem off. So...who knows how many hidden hp are there. It could be 1, it could be more. Whatever it is, I don't think it's much.
Old Nov 10, 2006 | 08:25 PM
EvoHung's Avatar
The Rnr Hks is Rnrs own modified version of the HKS. Better or not, I don't know. You would think the Rnr is better because of the 3 inch piping all of the way, but there are people using the original HKS with the tapering collectors who makes good power.
Old Nov 10, 2006 | 08:31 PM
HassounEVO's Avatar
One other difference between the actual HKS carbon Ti system and RNR's version is that RNR's is Stainless steel piping all the way from the cat (or test pipe) to the canister. HKS' uses coated mild steel piping. (Ryan had posted that on here somewhere)
Old Nov 11, 2006 | 08:51 AM
evo ippo's Avatar
i think that they just make the exhaust stick out a little more then the actual JDM one but the muffler HKS unit the piping is made by RnR
Old Nov 11, 2006 | 08:56 AM
19psi's Avatar
It's authentic but there are better options if you want an exhaust.
The RNR product is just "o.k."
You might have fitment issues as I did. It's really hit or miss.
Old Nov 11, 2006 | 09:03 AM
CharlieGsanD's Avatar
Thumbs down
id have to agree with this statment.....
My RnR Ti is a Genuine HKS muffler/can with RnR's own SS tubing, flanges & hangers
i believe only the tip is Ti
also, had some issues with my RnR exhaust as well, fitment as well as a broken hanger
Old Nov 11, 2006 | 10:00 AM
GPTourer's Avatar
Okay, I think everyone is clear that it is a genuine HKS muffler in the Rnr system, but my question is, is it a different HKS muffler then the one that comes with HSK's Evo system, one with a bigger internal diameter? Or does it have the same neck-down-in-cannister-beer-can-test-failing muffler?
Old Nov 11, 2006 | 10:32 AM
19psi's Avatar
It is the same.
It necks down inside the cannister.
It is not even close to 3 inches.
It's more closer to 2.5 inches.
Like I said before, there are better options out there.
Old Nov 21, 2006 | 05:17 AM
boostinjuice's Avatar
1. RNR has stated in another thread.. their exhasut is a full 3 inch tubing to the hks carbon ti muffler tip of 4.5 inch..(120mm)
2. HKS does make a universal Carbon ti muffler.. go to the website
Old Nov 21, 2006 | 10:24 AM
19psi's Avatar
I should've worded it better.
What I meant was, the piping is 3inches but the piping inside the cannister is not 3inches.
It's more like 2.7inch inside the cannister.
Old Nov 21, 2006 | 10:36 AM
SKILMATIC's Avatar
titnium just went up 50% in value over the last fiscal year. So expect all titanium parts to go up in cost.
nffox
Aug 12, 2007 11:35 PM
Evo05lution
Sep 25, 2006 10:34 AM
gl4662
Jul 12, 2006 11:35 AM
RalliArtEvoVIII
21
Dec 4, 2005 08:23 PM
RnR Racing
Aug 12, 2005 08:47 AM
