Boost Controller
Old Nov 14, 2006 | 10:58 AM
big_huff's Avatar
Boost Controller
Hopefully someone can help me out i have the profec b and its almost to where i want it, but in third, fourth, and prolly 5th havent tried it yet, if i am driving normally and when i hit 4,000 rpm my wasgate sounds like its opening it flutters a bit then closes on me while my foot is still on the gas. what is causing that and how do i fix it.
Old Nov 14, 2006 | 11:01 AM
kreionic's Avatar
What is your start boost set to?
Old Nov 14, 2006 | 11:13 AM
ihatepotholes's Avatar
set ur start boost at 14psi which is 140 on greddy unit's readout. regardless what u set ur startboost at, u'll have alil flutter. it's normal.
Old Nov 14, 2006 | 11:52 AM
big_huff's Avatar
it stutters and then my blowoff valve goes off while im still on the gas and my start boost is at 155.
Old Nov 14, 2006 | 11:53 AM
EDL's Avatar
EDL
well I have the profec B II and when I tunned my car I was boosting 24-25 psi but since I have stock wastegate it just keep fluttering a bit, and it depends on how many rpm you running because if you start boosting in 3k rpm it just make it worse. meabe the problem is wastegate or setting (get tunned Recommend)
Old Nov 14, 2006 | 12:18 PM
big_huff's Avatar
bump
Old Nov 14, 2006 | 04:07 PM
big_huff's Avatar
bump
Old Nov 27, 2006 | 10:48 AM
big_huff's Avatar
i had my set gain at 155 and it made my wastegate open up and close on me and i was told to turn it down to 120 -140 and i have it at 120 and it still does it. whats the deal, why does it do that? im thinking about selling it and getting a MBC.
Old Nov 27, 2006 | 11:13 AM
Warrtalon's Avatar
You don't know how to use the EBC, so you should go ahead and get a simple MBC - it will work perfectly right away.
Old Nov 27, 2006 | 12:09 PM
IMR-TIM's Avatar
I'll send you my settings along with what mods I'm running for comparison. This does take a while to search out, and everyone runs different settings, everyone has their own personal feelings about EBC compared to MBC. I'll try to help you out with what I got.
Check your PM from me
