Any IXs using the Invidia O2 housing and 3" turboback?
Old Nov 17, 2006 | 10:16 AM
tuffguy's Avatar
Do you have any clearance issues? If so, what's your setup? If not, what's your setup?
If I go with the Invidia O2 housing (2.9" outlet), I'd have to go 3" the rest of the way, right? I'm thinking of going with a 3" resonated test pipe (probably MR), and then the Road Race stealth catback, which is 3".
I'm not sure which 3" downpipe to get so I won't have clearance issues. Do you guys have any suggestions?
Lastly, are there any 2.75" resonated test pipes? I haven't been able to find any.
TIA
Old Nov 17, 2006 | 10:58 AM
travman's Avatar
If your going with a 2.75" dp get a 3" testpipe......
Old Nov 17, 2006 | 11:00 AM
tuffguy's Avatar
Thanks. I don't really want to go 3", but if the O2 housing is 2.9" and the only resonated test pipes are 3", I think that I have to.
If I could find a 2.75" resonated test pipe, I'd go with the MR O2 housing and the Espelier downpipe, but I can't find a 2.75" resonated test pipe.
Old Nov 17, 2006 | 11:14 AM
er0e's Avatar
My buddy is running the Invidia O2, Invidia N1 catback, invidia downpipe, test pipe. No fitment issues but a minor clearance issue with the 3 " downpipe. It can be fixed w/ washers or minor bending of metal.
Old Nov 17, 2006 | 11:17 AM
tuffguy's Avatar
That's what I was afraid of. Thanks for sharing and saving me the headaches.
Old Nov 17, 2006 | 02:57 PM
MR 600's Avatar
I am running a 3" DC downpipe with no issues on my EVO 9 MR. It clears just fine.
Old Nov 17, 2006 | 06:01 PM
MREvo2k6's Avatar
I have the invidia o2 housing and full 3" turbo back exhaust from perrin, the only fitment problem was fitting the 02 housing to the turbo side, the holes dont match up for anything. but other than that it works fine and gave a little more power.
Old Nov 17, 2006 | 07:33 PM
tuffguy's Avatar
Thanks guys. I'm gonna go with the MR O2 housing. It's 2.5", not 2.3" as advertised on Lancershop, so it's not as bad. Mated with a 2.75" downpipe, it should help me get some more bottom end torque. 3" after that. Rally cat (well, gotta find out how much that costs first) and RRE stealth catback.
Old Dec 27, 2006 | 08:29 AM
MitsuJoe's Avatar
How did you remedy this?
Old Dec 27, 2006 | 11:16 PM
trinydex's Avatar
drill? dremel?
cla2000
Jul 25, 2016 04:04 AM
gkswhdl88
Mar 17, 2015 05:21 PM
P!N-EVOVIII
Mar 14, 2010 10:50 AM
SloEvo12
Jan 20, 2009 11:30 AM
J8dailo
May 30, 2006 11:45 AM
