climate control!?!?!?!?!?!
Old Nov 28, 2006 | 06:52 PM
blackblaze427's Avatar
when i first got the car the hot/cold knob was really hard to switch back and forth and you would really have to reef on it to get it to either hot or cold. has anyone else had this problem??? i got so pissed cuz it got stuck in the middle and it was cold out so i went to turn it again and the plastic stud friggan broke!!!!!!!!!!! i havent taken it apart or even thought about it until now but does anyone know what this might be? thanks for any input guys
Old Nov 28, 2006 | 07:07 PM
pers785's Avatar
I have the exact same problem on my 03. It hasnt broke or anything, but its a struggle to get the knob from one side to the other, so im hesitant when I do it. I thought it was just mine, but I guess not....
Old Nov 28, 2006 | 07:09 PM
dEdiYT11's Avatar
same problem here. snapped right off
Old Nov 28, 2006 | 07:11 PM
Bigl4201's Avatar
I had this problem in one of my other cars, I found that turning off the heat/ac/fan freed up the tension in the knob(s). im not sure why but it worked. Did you guys have the fan on when you noticed this ?
Old Nov 28, 2006 | 07:14 PM
3vo2005's Avatar
quality is superb.
I say you go to the dealership.
Old Nov 29, 2006 | 01:02 PM
yah i live in maine and it isnt exactly warm when i wake up at 4am so im going to call my dealership right now and see if its covered under my warrenty. ill let you guys know what i find out
Old Nov 29, 2006 | 01:11 PM
KevinD's Avatar
you all have the 03 climate controls. there is a cable slider you can get from a 04 or newer that wont have this problem. the location is under the dash driver side, where your right knee would be. DEVO330 has the part number and he is doing the conversion on his car. send him a PM for further info.
Old Nov 29, 2006 | 01:17 PM
thanks for the info man
Old Dec 24, 2006 | 02:22 PM
what a horrible design by mitsu!!!! i was looking at it and there is the most unessacary rise right in the middle(between hott and cold) can be fixed with a dremel or a small die grinder!!
Old Dec 24, 2006 | 04:43 PM
kreionic's Avatar
Same problem on my old 03 but its fine on the 06
