Which model should I buy, Tranny dependent?
Hi all, from looking through a bunch of old posts it seems that all the warranty issues evo owners encounter seem to be transmission related (the 4g63 seems to be bullet proof, even with mods). Does the six speed fail more frequently then the five speed. And If you could purchase your evo over again which model would you pick and why.
Again thanks for your patience and insight.
-Kamak
-Kamak
Also forgot to ask, what options? I'm not a SSL guy, I'm more into performance. Do things like the vortex generator, front anti sway bar, rear anti sway bar, additional spoiler lip thingy and corner air dam extensions make a difference, better yet what is worth the money and what is crap.
the 6 speed has more problems than the 5 speed, which are stronger since there's one less gear (they were able to make the gears thicker)
if I had a chance to rebuy...i think i would've gotten a MR since i do a lot of highway driving and i would like that 6th gear. i had to adjust to driving a 5 speed since i drove a s2000 quite a bit before
but the 5 speed is the favored weapon of choice
I have a IX with the 5 speed. Its been in the shop for 3rd gear grinding. They said iit was fixed and not too far down the road it started doing the same thing. I havent had the chance to take it back yet. Thats my only complaint.
5 speed is a more bulletproof tranny, the MR 6speed tends to be a bit weaker. Dont believe me? Do a search and also look at all the high HP and low 1/4 mile times....ALL of them are base EVOs, never MRs.
I am at 50k in my 03 with a 5speed. Not a single problem, TC case is fine, tranny is fine, NO grinds, NO lockout, etc.
Surprisingly i got 49k outta my stock clutch also, and that was with quite a bit of abuse (autoX, drag, launching, fun on the highway) I just earlier today ordered an Exedy Twin HD clutch with flywheel and factory TOB. I am in utter awe that i got almost 50k outta the stock clutch especially with my modifications.....but the clutch is at the VERY end of its life, since 45k i have had a lot of clutch chatter along with a hard time getting it to hold above 5k launches. The exedy will take care of ALL my problems!
Originally Posted by kilgoja
what is the deal with t-cases?...what causes them to go out?
