Oem Vortex generator gap
Old Dec 11, 2006 | 10:23 PM
vegasevo9's Avatar
Hello everyone. I just installed a oem vortex generator. I did everything instructed on the manual. There is still a gap on the fin when facing the wing... Is this normal? Or do i have to use a hair dryer and install it again? Thanks in advance guys.
Old Dec 11, 2006 | 10:39 PM
EVIL MR's Avatar
you have a gsr not rs or mr with the other roof
Old Dec 11, 2006 | 10:47 PM
vegasevo9's Avatar
Ic. So it is normal then. You are saying it only fits perfect on the aluminum roof?
Old Dec 11, 2006 | 10:49 PM
crasher's Avatar
awww dude that sucks, i test fit mine first, and then needed to do modding to the inner edges where the generator lifts up....
pretty much if you really want to fit it and make it perfectly flush with your roof, you need to peel it off but that will ruin the double sided tape, you can always get more of that though.
Ive posted a howto on here in the forums regarding howto modify your vf in order to fit flush, but all you need to do is get a soldering iron and melt the inner edges where it fits onto the roof at the edge, you need to make it rounded not squared. The ix mr edition has a more squared roof edge, evo ix's dont have the edges squared.
i just kept melting the inner edges of the vg and it fit beautifully.
Old Dec 11, 2006 | 10:51 PM
vegasevo9's Avatar
Thanks for the info! Will take it off right now and do it again.
Old Dec 11, 2006 | 11:12 PM
Soundave's Avatar
I had the same problem. It is an eyesore sometimes, but I guess I'll try to fix it when the weather clears up here.
Old Dec 11, 2006 | 11:32 PM
vegasevo9's Avatar
Would it affect ride when at high speed?
Old Dec 11, 2006 | 11:54 PM
vegasevo9's Avatar
Fixed! I used the same 3m tape. It was still sticky. I am going to be able to sleep now.
Old Dec 12, 2006 | 08:49 AM
Dumb_Dog's Avatar
I have the same problem, there is a gap after the 3m tape, and it even make noise when doing 70 + on highway, may be I didn't do it right, but instead of the 3m tape, get some silicon glue/gasket maker, that fixed mine, it won't damage the paint either, works great
Old Dec 12, 2006 | 10:06 AM
skiracer's Avatar
I used silicon caulking to fill in my gap...
firmk20
May 19, 2016 08:45 AM
kyoo
Mar 8, 2016 06:32 PM
silverbullet04
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 10, 2008 08:47 PM
Kins
Dec 19, 2007 10:01 PM
o6RSEvo
Sep 11, 2006 04:39 PM
