Gap Between Roof & Vortex Generator
Old Jan 28, 2016 | 07:32 AM
kyoo's Avatar
Noticed there's a decently spaced gap between my roof and the vortex generator... This is on an MR, vortex generator from the factory. If I wanted to seal this/close it up, what would be the best way to go about it?
Old Jan 28, 2016 | 09:26 AM
nor11384's Avatar
FCOTM Winner
I would say take it off, clean the glue/tape off and put it on with double sided tape...that's how I did mine...
Old Jan 28, 2016 | 10:10 AM
Kreeker's Avatar
Is this gap towards the ends of the VG? I have an OEM VG that I installed on my evo and it seems to curve up as it gets closer to the end of the right and left side of the car.
Old Jan 28, 2016 | 10:38 AM
kyoo's Avatar
i'll have to take a look, but I believe so...
Old Jan 28, 2016 | 11:01 AM
APEXR's Avatar
Not an MR owner, but received my VG for an X-mas gift. It did come with sticky tape from Mitsu, but does have a small, roughly 1" long, gap on both sides. Just large enough to catch pine needles.
My best guess to seal it up would be to mark the roof along the front of the VG, pull it, hopefully not breaking it, & then apply silicone along the tape line & reapply with new double sided tape. Just my 2¢.
Old Jan 28, 2016 | 04:47 PM
nor11384's Avatar
FCOTM Winner
really? I don't have an mr but have a vg and I don't have this problem...
Old Jan 29, 2016 | 07:38 AM
Kreeker's Avatar
This is what mine looks like it. It's OEM but I installed it.
Old Jan 29, 2016 | 08:02 AM
kyoo's Avatar
i'll try to take a look this weekend, been really busy
Old Mar 7, 2016 | 08:31 AM
isiz's Avatar
What did you guys find out on this one? I have an OEM piece painted and I have noticed the same issue at the corners when test fitting. I have heard this could be due to the VGs being designed to fit the aluminum roof only and that it may be dimensionally different. I don't know if this is true or not.
Old Mar 7, 2016 | 12:14 PM
bluepeartype-s's Avatar
Registered User
I've got an OEM Apex Silver one. I bought mine when you could pick the stock color you wanted back in the day. Anyway, my point is the mines a GSR and it fits flush to the roof. I don't think this has anything to do with the trim level car you have.
O.P. I agree with others that have posted. Take it off and re-apply 3-M double sided tape and remount again.
-BMH
Old Mar 7, 2016 | 12:18 PM
meckert's Avatar
-BMH
^^^ I don't think the VG has d-sided tape all the way around the roof line and it gaps as a result.
Old Mar 7, 2016 | 12:28 PM
Registered User
Whatever.. I checked out Rexspeed. They use 3M adhesive. I'm not sure about OEM. You got the point though.
-BMH
Old Mar 8, 2016 | 06:32 PM
isiz's Avatar
The shop that painted mine put tape on (3M I'm pretty sure) but it is right on the edge, almost no spacing so I think I will remove it, use some adhesive promoter and place some 3M VHB on there where OEM has it. Maybe the fitment will be better that way.
Does anyone know if OEM uses an adhesive promoter on the paint side? I'm hesitant to use one in case it damages the paint. My plan is dish soap to strip any and all wax and then isopropyl alcohol, little bit of heat and stick it on but curious about adhesion promoters on the paint.
Onkar02
17
Jun 9, 2010 10:43 PM
mrblondelv
Dec 2, 2009 09:40 PM
vegasevo9
Dec 12, 2006 10:06 AM
o6RSEvo
Sep 11, 2006 04:39 PM
