Looking for a certain BOV sound
Old Dec 14, 2006 | 09:45 AM
MalibuJack's Avatar
Originally Posted by SmikeEvo
Not totally correct. The HKS unit doesnt open at idle. Our DVs will open at idle a little bit to let some air back into the intake. This keeps our MAF happy.
Its not that it keeps the MAF happy, but the airflow at idle and the MAF is calibrated for this, so the HKS does throw the stock tune off a bit..
I run an uncirculated HKS SSQV, and for my no-maf application it works great.. However it SUCKS on a stock MAF equipped car circulated or not, it makes tuning tricky on a stock MAF..
I would STRONGLY suggest that most people do not change their DV unless they have a need to. aftermarket DV's offer very little performance benefit, and generally hurt drivability, until your at the point where your boost levels and tune are causing them to leak.
Old Dec 14, 2006 | 09:48 AM
TogueMonster's Avatar
the Greddy Type S with a single spring mod and an HKS EIDS is what you want. That will get you what you are looking for. These other dudes are just effing with you. Just answer the guys question and let the thread die.
Old Dec 14, 2006 | 09:53 AM
Smike's Avatar
What? Im being serious, you cannot run VTA with MAF. No ifs, no adds, no buts...I never said the Type-S recir was bad (thats what I have). I will not truthfully tell someone to mod their car in a way that hurts the performance of the car. I will point them in the right direction. VTA with EIDS still isnt a solution for an Evo.
+1 Billion.
Old Dec 14, 2006 | 10:36 AM
nolimits1320's Avatar
Thanks for the info on the HKS, I wasn't aware that the factory diverter valve was open on idle!
Old Dec 14, 2006 | 11:11 AM
MalibuJack's Avatar
the HKS EIDS is JUNK, worthless on the Evo.. It is a "Buffer" that smooths the signal, and as a result EFF's up the cars response and will hurt your performance and since the signal is buffered, when you shift at higher RPM your RPM's will shoot up until the signal drops.. Add that to an overly-stiffly sprung BOV and your asking for trouble.
This topic has been covered before..
1) Keep the stock DV when possible
2) Ignore the desire for "The sound"
3) pre DV MAF cars don't respond well to BOV's
4) If you want to do this, its obvious performance is NOT the reason
5) Almost anyone who does a VTA BOV on an EVO with a stock MAF will be ridiculed mercilously, simply because it HURTS the performance, drivability, and reliability of the car.
Old Dec 14, 2006 | 11:16 AM
Greg K's Avatar
listen to the man kiddies, there's a reason MJ has "guru" under his name...
Old Dec 14, 2006 | 11:27 AM
EVOBrad's Avatar
+1
Seriously, forget about the aftermarket BOV and put your money toward something useful.
Old Dec 14, 2006 | 11:38 AM
Ph3n1x's Avatar
MJ always is a good read, something always to learn from him. If i ever meet him i owe him a beer.
Old Dec 14, 2006 | 11:58 AM
drewblueeye's Avatar
right now i have th Forge RS BOV, it works great, just curious if there was another one that works great but with more of a squeaking noise. didnt mean to get everyone all worked up, LOL
Old Dec 14, 2006 | 12:04 PM
vegasboy301's Avatar
Old Dec 14, 2006 | 12:13 PM
EVOBrad's Avatar
Yup. Same thing with Warrtalon. Both of them are great at translating their knowledge into a coherent post. Have a question? Just dig through posts by MJ or Warrtalon and there's a 95% chance you'll find an answer that makes sense!
Old Dec 14, 2006 | 12:16 PM
EVOemJEN's Avatar
i have a turbo excess one, it makes a psh sound and then a light squeak sound ill sel it for $60
Old Dec 14, 2006 | 12:32 PM
Ev0ikon's Avatar
Im working on a magic box that will require a radio relocation kit. This box will have a bunch-o-buttons on it and one of them will make that "sneezie" sound. It will locate near my shifter so I can bang into it every shift to make various BlowOff sounds.
Now I gotta go collect all these sound samples. :P
Old Dec 14, 2006 | 03:42 PM
-=SPECTRE=-'s Avatar
I'm laughing so hard at this I'm crying
Part throttle driveability with a VTA BOV = FTL
Old Dec 14, 2006 | 03:49 PM
purevibez's Avatar
+1, he's steered me in the right direction to tuning and with all my newb evoscan & ecu flash questions too. id go with him on this one. plus out of my own experience. screw the sound.
