AC not working...
Old Dec 24, 2006 | 01:45 PM
Ph3n1x's Avatar
AC not working...
Well the other day rain was falling so I went ahead to put the AC on cause it was getting hot. To my amazement no cold air comming in. The condensor doesn't seem to cycle on either.
At first I thought it was a fuse, so I went to fuse panel and there is like 4 fuses for the AC. Does anyone know the difference for each?
Old Dec 24, 2006 | 01:49 PM
ddubdb3's Avatar
are any of them blown
Old Dec 24, 2006 | 01:50 PM
evrblazin's Avatar
it must be hot there on cloud 9 no ac in phil
Old Dec 24, 2006 | 01:51 PM
Ph3n1x's Avatar
There are the normal small 2 prong types rated at 30amps each that seem ok. The other 2 are the ones im not sure about. You can't tell by looking at them.
Old Dec 24, 2006 | 08:25 PM
Sschmuve1's Avatar
Where are you located? I'm not sure about the Evo, but the ac compressor usually doesnt come on in cold weather.
Old Dec 25, 2006 | 09:56 AM
Ph3n1x's Avatar
Florida.
Old Dec 25, 2006 | 10:09 AM
ak47po's Avatar
What problem best describes whats going on.
Old Dec 25, 2006 | 12:07 PM
Ph3n1x's Avatar
1,4,5 it looks like
Old Dec 25, 2006 | 05:36 PM
glgz's Avatar
You could have a leak and be to low on frezon for the compresser to turn on,
Old Jan 2, 2007 | 10:13 PM
Ph3n1x's Avatar
What I notice is the cooling fan on the Radiator does not come on, even after Ive had the car idleing for awhile.
Also normally i get a slight feedback on my speakers when my AC is on. now i don't when i switch it on.
Old Jan 6, 2007 | 06:30 PM
Ph3n1x's Avatar
Ok so it turns out i was purged the low side AC port and nothing comes out, so i figure i have a leak.
Put in a can of Dye Dector 134a and turn the car on and ac.
After a while i see some smoke comming from my o2 housing area by the wastegate where it connects onto the hotside.
Turn off the car and i hear this hisssing sound...like when i tire is going flat and vapor comming from the radiator back section, condensor.
looks like ill need a new condensor....To the dealer i go....
Old Jan 6, 2007 | 06:40 PM
purevibez's Avatar
got one better. have freeon. fan comes on. ac blows but just doesnt get cold. and the compressor clutch doesnt come on. the fuses are all good.
what do u guys think
not trying to hi jack the thread but almost the same problem.
Old Jan 6, 2007 | 06:41 PM
Ph3n1x's Avatar
Check the lowside port and stick a scredriver in it, like what you do on tire valve stem and see if anything comes out.
Old Jan 6, 2007 | 06:42 PM
purevibez's Avatar
this is what im kinda thinking also. needs to be recharged. it is a 03 and never been touched before. plus sometimes i dont turn the a/c on for a few weeks. rather have the windows down or its cold like now.
Old Jan 6, 2007 | 06:44 PM
purevibez's Avatar
did that. white gas( i hope its freeon) comes out. funny i tried to turn mine on because it was raining too. go figure
