Evo Headlights not balanced
Old Dec 25, 2006 | 04:41 PM
vegasevo9's Avatar
My friend just noticed when he was in front of me that my left headlight is a little brighter than my right one. Which means it is tilted alittel upwards. Once i got home i checked and it is true. My car is only 2 months old. Is this normal or is it just me?
Old Dec 25, 2006 | 04:43 PM
ak47po's Avatar
Take it to the dealer.
Old Dec 25, 2006 | 04:45 PM
nk1124's Avatar
its normal, if you search it was discussed a couple months back. It has something to do with having the driver side lower to not blind incoming traffic.
*edit* Oops!! if your drivers side headlight is higher that is odd, the passenger side headlight is supposed to be higher. Cant really tell if you mean left side from inside the car or looking at the car from the front.
Old Dec 25, 2006 | 04:46 PM
vegasevo9's Avatar
Thanks for the quick reply. I will search right now. Merry xmas guys.
Old Dec 25, 2006 | 04:51 PM
vegasevo9's Avatar
Yup left headlight from inside the car. I am wondering how i can explain that to the dealership when i go there during the day?
Old Dec 26, 2006 | 05:35 AM
prj.evo's Avatar
Is there any way to aim the HID lights besides using the electronic aimer inside the car?
Old Dec 26, 2006 | 11:19 AM
Soundave's Avatar
You can adjust it manually in the engine bay. You can either use a screwdriver (which chewed the gears on the adjustment knob on mine) or a 10mm socket. The adjustment knobs are near the back of the highbeams.
Old Dec 26, 2006 | 11:59 AM
MasterNater's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=75583
Old Dec 26, 2006 | 12:03 PM
bvdawg13's Avatar
if the car is only 2 months old, u must still have warranty, i would just take it to the dealer...i've never noticed anything about my driver headlight being lower
Old Dec 26, 2006 | 03:50 PM
ernald711's Avatar
was your friend in a car infront of you... if so, then it might just be perspective since he does sit on the left side as well. close ur garage and sit in they driveway to see if your beams are stragiht/level , assuming your driveway is level also.
Old Dec 26, 2006 | 05:29 PM
gsrboi80's Avatar
Driver side HID will sit slightly lower than passanger side so you dont blind on coming traffic. Its opposite in japan
Old Dec 26, 2006 | 05:32 PM
SiCKlEyWiKeD's Avatar
it's not just the Evo. Every car is like that. Even cars overseas
Old Dec 26, 2006 | 08:43 PM
vegasevo9's Avatar
I checked this morning inside my garage and it is not balanced...
Old Dec 26, 2006 | 08:47 PM
3SgteGuru's Avatar
You sit on the Left side, So when its only you in the car the left light is slightly lowered, Therefore when you are not in the car the light appears higher.
Evo47
Jan 17, 2017 12:26 PM
evoDON
Mar 3, 2015 09:21 AM
emperor496
Dec 24, 2013 12:55 PM
kkmoslehpour
Mar 17, 2011 07:24 PM
anjapower
Mar 20, 2010 12:35 PM
