70 awhp gain on tune!!
If your base run was 238 on this particular dyno, what do other stock Evo IX's do on this dyno? What were you using to tune your car, and or who tuned it? What were the AFRs? What octane were you running? Sorry for all the questions. Either way those are really good numbers.
I had my evo 9 dynoed on a DD awd dyno at beyond redline in Greenbay. With a conefilter, 3 inch tubo back, high flow cat, street tune by dyno flash and 21 psi i made 304 hp 307 tq. Im going to put on ams upper and lower ic pipe and a turbo xs front mount. I hope to make 330hp 335tq
you need a test pipe... 23 pounds of boost on 93... and meth/alky kit at 26/27 pounds will wake her up nicely... should put you around 370-380whp
