oem plastic bov vs metal oem bov quick question
Old Jan 26, 2007 | 10:17 AM
zeus1's Avatar
i had my stock plastic bov swapped out for a metal oem one. my boost guage after swapping the bov's shows the peak boost holding 1-2psi higher? what would cause this to happen? i turned down the mbc but curious what could cause this.
Old Jan 26, 2007 | 10:19 AM
pwrofturbo's Avatar
The plastic one leaks.
Old Jan 26, 2007 | 10:23 AM
zeus1's Avatar
ok thanks..
Old Jan 26, 2007 | 10:31 AM
shupadupa's Avatar
I think there should be a preface on "the plastic one leaks" comment. OEM stock boost it doesn't leak. higher boost it may leak
Old Jan 26, 2007 | 10:33 AM
ultimatesteve's Avatar
Not always true. Mine only held 16psi after about 30,000miles. put a ix on and its fine.
Old Feb 5, 2007 | 08:07 PM
bk.adams's Avatar
The plastic one sucks!!! I mean leaks....found that out on my 2g Eclipses. Even at
stock boost.
Old Feb 5, 2007 | 08:50 PM
Evo8's Avatar
Your problem fixed, stocker leaks for sure.......Everybody agrees - case closed
Old Feb 5, 2007 | 08:51 PM
Warrtalon's Avatar
You bet your *** it does. You just can't see it.
Old Feb 5, 2007 | 08:56 PM
blackbichGSX's Avatar
We tested one on an 03 Evo when the Evo's first came out. At 8 psi you could hear a small leak, at 13 psi it began to leak a fair amount, more than you would want. These things are well known for leaking since the 2G days. This is the main reason for people using the 1G BOV.
Old Feb 5, 2007 | 09:05 PM
Warrtalon's Avatar
I pressure tested mine, too, and the valve opened at 13psi. Then, my JDM MR DV didn't open all the way up to 24psi.
Old Feb 5, 2007 | 09:11 PM
w evo's Avatar
^^^ what he said...those are the numbers I saw as well.
Old Feb 6, 2007 | 12:22 PM
EVO8emUp's Avatar
My plastic one leaked just by blowing into it. Damn bean counters!
Old Feb 6, 2007 | 04:56 PM
the1andonlyE's Avatar
Plastic sucks metal is better
[p]dOG.
Oct 13, 2016 11:13 AM
whotippedmycow
Aug 25, 2013 12:29 PM
Thoe99
Jun 27, 2009 07:15 PM
Box Rocket
12
Sep 5, 2008 01:04 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
11
May 6, 2007 11:06 AM
