Please help.
Old Feb 14, 2007 | 01:40 PM
exhaust_note's Avatar
Please help.
Went to work today and when it was time to leave. The car would not start. When i would take the keys out the dash lights would all still be lit up. When i disconnect the negative cable and reconnect it a wierd clicking noises happen right behind the battery. And the dash lights will all illuminate w/o the keys in the ignition. THis all happend after this ice storm we just had in South Jersey.
someoen please help
Old Feb 14, 2007 | 01:43 PM
Evo8's Avatar
What's up with all these electrical problems I keep hearing?? And most of them do happen when it's snowing or cold out.
Old Feb 14, 2007 | 01:46 PM
smokedmustang's Avatar
Is the fuse blown by the positive battery terminal? The fuseable link on the battery cable?
Old Feb 14, 2007 | 01:49 PM
tweakdsm's Avatar
I would check the battery, its probably dead, the clicks you hear when you connect your neg. back its normal. Try to use jumping cables
Old Feb 14, 2007 | 01:51 PM
Inspite's Avatar
Sounds like you have a bad battery. Get a jump, and drive to autozone or the like.
Old Feb 14, 2007 | 01:53 PM
if its a bad battery... how come the car stays running once i take the key out.. and after i stall it off. disconnet the battery, reconnect it and the lights on the dash come on w/ no key in the ignition.
Old Feb 14, 2007 | 01:54 PM
i cant even start the car now cause the light on the dash are lit w/o the key and i go to start it and it will turn but not fire over.
Old Feb 14, 2007 | 02:01 PM
and ill take the key out, everything will shut off on the dash. the car keeps running. i put the car into reverse gear and it shuts off.
Old Feb 14, 2007 | 02:03 PM
There are faulty ignition switches. Try this, use the SPARE KEY, and see if it still does it. SERIOUSLY.
Old Feb 14, 2007 | 02:08 PM
lexat20's Avatar
Sounds like a bad cell in your battery.
nope didnt work.. when i walked out into the garage all the dash lights were on though
Old Feb 14, 2007 | 02:26 PM
Sounds like a short somewhere. Wish I could help more.
Old Feb 14, 2007 | 02:29 PM
im gonna let it dry out over night in the garage and see if that works.
Old Feb 14, 2007 | 06:10 PM
joeMama's Avatar
sounds like you need a mechanic and a test light. you have a short somewhere in the system. you have any after market electronics installed lately?
Old Feb 14, 2007 | 06:18 PM
KartaRailed's Avatar
Staying on with the key removed? Sounds like you have a turbo timer... The car is shorting out somewhere on the body.
