I thing I just found some bad news :(
Old Feb 17, 2007 | 04:31 PM
4WS Tuning's Avatar
Originally Posted by sabastian458
If it is in gear, should all four not spin? or if the front can still spin, shouldnt there be some resistance to spining?
its fine.. mine does the same thing...
in gear the wheel will move... if u had no lsd's then it wouldn't move..
like smokedmustang said... go get drunk.. its saturday night, 30 min and im out of work =-p
Old Feb 17, 2007 | 04:32 PM
smokedmustang's Avatar
Old Feb 17, 2007 | 04:34 PM
sabastian458's Avatar
Originally Posted by smokedmustang
If you turn the front wheel in one direction, does the other wheel spin in the opposite direction? It should.
Yes. I also went and let the E-break down and spun the wheels. Only the front will spin if spining a front, and if spinning the rear only the rear will spin.
Old Feb 17, 2007 | 04:36 PM
Crap on it, Im going and getting some drinks. Let ya'll know what I find next week when I pull the transmission & transfer.
Old Feb 17, 2007 | 04:41 PM
Keep us posted. I say you're fine!
Old Feb 17, 2007 | 05:12 PM
althemean's Avatar
You're fine. The acd is a viscous clutch anyways. It will always spin one set or the other seperately when off the ground. When I had mine jacked in the air, to break the hub nut (not lug nuts) I just had my wife step o the brakes real hard and it held enough the fronts still. You could try the same trick for breaking your lug nuts.
I did the same exact job you are doing right now...so if you need any help...PM
Old Feb 17, 2007 | 07:31 PM
mot's Avatar
mot
read your manual it says with the e brake locked it disengages the rear diff
so with the e brake on the wheels wont spin in the back and the 2 fronts will spin together
