how much labor (in time) would this take
Old Mar 9, 2007 | 09:03 AM
filter's Avatar
install cosworth cams and arp headstuds. hes installing the head studs the proper way.
Old Mar 9, 2007 | 09:04 AM
TURBevO8's Avatar
I would say 3-5 hours depending on your experience level.
Old Mar 9, 2007 | 09:06 AM
filter's Avatar
he qutoed me 8 hours. Just didnt know if this was too much.
this guy goes great work i've seen other vehciles done by him. My friend had his 350z engine turboed and completely rebuilt by him. And my other friend just had his 350z turboed by the same guy. so i know his work is top notch.
Old Mar 9, 2007 | 09:08 AM
UT_Evo's Avatar
Has he done cams on an Evo before? If not, than 8 hours is about right, its the common quote here too... If he has done cams on the Evo at least once or twice than it shouldn't take more than 5 hours, and that's if he's meticulous.
Old Mar 9, 2007 | 09:17 AM
ries's Avatar
+1 ^^^
he might have overestimated too so that if he gave himself plenty of time and didnt end up overcharging you for labor if he went over...should take around 5 hours though if he's done an Evo before, a little longer if he hasnt
Old Mar 9, 2007 | 09:23 AM
filter's Avatar
thanks guys.
Old Mar 9, 2007 | 10:26 AM
joeMama's Avatar
Every job is on the books for way more time then they actually take! Thats no secret...
Old Mar 9, 2007 | 10:35 AM
Kee1pride's Avatar
cams do absolutely not take 8 hours to do. done and helped do it multiple times now and it's a 2:45 minute job if you know what you're doing and a 4-5 hour job if you're a retard.
Old Mar 9, 2007 | 11:50 AM
filter's Avatar
are you guys missing the part about doing the head studs too?
i said cams and head studs.
Old Mar 9, 2007 | 07:02 PM
Jakeg97's Avatar
6 hours
dont forget to bleed the lifters
Old Mar 9, 2007 | 07:06 PM
Curt@MrLed's Avatar
Former Vendor
what do you mean the right way...
Old Mar 9, 2007 | 07:11 PM
lightspeed1's Avatar
This guy may me a great tech, and meticulous.... BUT I think he is either qouting high to make him look like a saint and give you a 3hr discount at the end, OR he's is qouting for how fast he works...(for example:.... (stoned) 8.75 hrs. , (drunk) 11.25 hrs. , (on crack) 47 minutes. ) You get the point...
Old Mar 9, 2007 | 08:34 PM
filter's Avatar
my taking the head completly off and torqueing and installing to arp standars (instructions) not taking one off then putting one on with the head still on.
Old Mar 9, 2007 | 11:23 PM
popadel's Avatar
thats crazy. i have the same st up and valve train and took 8 hours???? id say for cams and studs alone - 4,5 hours max!
any why are you removing the head to do studs??? whats the benefit unless you change gaskets. remember that with studs you can increase the torque by about 50Nm per stud compared to stretch bolts so the stock headgasket will hold just fine as long as you follow a zig zag patern and torque evenly as you move along.
my 2c
Old Mar 10, 2007 | 06:10 AM
filter's Avatar
my 2c
everything i read said to avoid that doing like that. he said he would do it any way i wanted.
