How much boost are you running?
Old Mar 14, 2007 | 05:27 AM
Chemwarrior's Avatar
22 psi; mods are in my sig
Old Mar 14, 2007 | 05:35 AM
Boltz.'s Avatar
FCOTM Winner
26psi - 93 only
TBE/Intake/BPV/LICP
Old Mar 14, 2007 | 05:49 AM
PKEVO8's Avatar
1.5 bar so ~22psi. Mods include APS TBE, Agency Power intake, Forge BOV, XS engineering FMIC, AMS LICP, Borla turbo manifold, and an mbc
Old Mar 14, 2007 | 05:59 AM
aalzuhair's Avatar
New to the EVO world so I'm only running ~1.20bar. I will increase boost as I get more familiar with the car
I have an EVO 9 RS (I guess its Middle East specs, which is also called as I have learned a “General export specs”) with the following bolt on’s: SARD FRP, JIC cat back, HKS down pipe, GT Spec exhaust manifold, AMS fuel rail, Alcohol injection system, Greddy boost controller, Greddy Turbo timer, Cusco Trunk Bar, Excedy twin carbon clutch and Koyo radiator.
Az
Old Mar 14, 2007 | 06:06 AM
mac74's Avatar
24 psi, Fuel pump. 680 injectors, tbe, High flow cat, Intake, 272 cams. 373whp Tuned by Turbo Trix!!
Old Mar 14, 2007 | 06:09 AM
Waz996's Avatar
Me Works P2R Flash, peaks 25psi, settles 22psi..
Old Mar 14, 2007 | 07:52 AM
Warrtalon's Avatar
That's 3psi less than stock. NO reason to do that and certainly no reason to have all those mods if you're going to run such low boost.
Old Mar 14, 2007 | 07:54 AM
V.8MR's Avatar
Az
Old Mar 14, 2007 | 07:59 AM
EvoRecordSetter's Avatar
Originally Posted by smilely
I"M running 28-30 PSI and Holding 26-27 ish at 8000rpm's. 450 whp/450 wtq on mustang dyno.
450 whp on mustang dyno on a white rabbit? is that like the highest?
Old Mar 14, 2007 | 08:05 AM
Pure Playaer's Avatar
23.6 With mods in my sig With 93 Octane
Old Mar 14, 2007 | 08:46 AM
4Gsixty3's Avatar
23psi on pump!
Old Mar 14, 2007 | 08:47 AM
kreionic's Avatar
23.5psi. on pump Stage 1-2
Old Mar 14, 2007 | 08:50 AM
APEX1's Avatar
25 psi and when I dont run race gas 22psi
Old Mar 14, 2007 | 09:48 AM
vortech_g35's Avatar
AMS GT35RL Kit
AMS FMIC
AMS 680cc Injectors
AMS Intake
AMS UICP, LICP
AMS Fuel Rail
255 Fuel Pump
Arp Heat Studs
AEM Tru Boost
AEM EMS
HKS Carbon Exhaust
AMS Test Pipe
more little stuff...
Boost: Being installed on car as we speak!
Old Mar 14, 2007 | 09:51 AM
UT_Evo's Avatar
With the stock turbo/manifold set-up running more than 21 without proper gas can cause problems.
