How much boost are you running?
Old Apr 18, 2007 | 12:43 PM
  #76
Sassaphrass's Avatar
1.5 bar with just a flash
Old Apr 18, 2007 | 03:30 PM
  #77
Tuner@Swift's Avatar
Holding 30psi from 4500rpm to 6000rpm, then tapering to 22psi @ redline. With the 280 cams, the stock turbo runs out of breath after 6500rpm. Mods as listed below.
Old Apr 18, 2007 | 03:32 PM
  #78
mievoIX's Avatar
23-24 psi on 93 oct, holds at 21-22. turbo back, high flow filter, stock BCS with pill removed, tune.
Old Apr 18, 2007 | 03:41 PM
  #79
vortech_g35's Avatar
21 psi
Old Apr 18, 2007 | 04:18 PM
  #80
El.BlueEvo9's Avatar
The Sig. says it .
Old Apr 18, 2007 | 07:56 PM
  #81
chrismnj's Avatar
25 Psi
Old Apr 18, 2007 | 08:37 PM
  #82
MRevolutionRed's Avatar
Originally Posted by EVOllie
Did anyone else catch his HP number? was that supossed to be 345?
i mean we know buschurs dyno is crappy but if you only have 245 whp with those mods something is definetely wrong.
Old Apr 19, 2007 | 11:34 AM
  #83
TurboIX's Avatar
I know people are not holding more than 20psi after 7k...i redline at 7800 and it always drops to 18-19psi... 3500 -6500 rpM I get 26 spike and hold 24 then slightly drops to 22 then at 7K+ it's 18-19psi.
Old Apr 19, 2007 | 05:44 PM
  #84
jcdevo67's Avatar
im running 21-22 dropping to 19 at most at redline. mods are in sig
Old Apr 19, 2007 | 05:49 PM
  #85
Ralph's Avatar
1.93 Bar
Old Apr 19, 2007 | 06:02 PM
  #86
LoCo4's Avatar
23 psi....mods in sig.
Old Apr 19, 2007 | 07:04 PM
  #87
dsmfan95's Avatar
I can hold 22psi to 8000rpms on pump gas. No spike, just a flat 22psi from ~3800-8000rpms.
Old Apr 19, 2007 | 08:04 PM
  #88
ninekrevs's Avatar
24psi 93 pump gas
Old Apr 19, 2007 | 08:12 PM
  #89
Jax419's Avatar
20
Old Apr 20, 2007 | 07:50 AM
  #90
dsmfan95's Avatar
Originally Posted by ninekrevs
24psi 93 pump gas
