RMR intercooler pipe kit pictures
Old Apr 22, 2004 | 06:57 PM
Chris in HB's Avatar
Originally posted by k270kmh
What kind of modifications Do I need to do to install RMR interc. piping kit? It is a bolt on kit? Because once one guy told me that he had to weld some parts to install a Ralliart piping kit...
Can I intall RMR interc piping kit together with my stock air box?
There are no mods required (ie welding or fabrication), but you will need to trim a couple of the hoses and you cannot use the stock airbox. You still can retain the stock battery, etc. I am not sure if RMR's site has step-by-step instructions for the IC pipes or not.
Old Apr 22, 2004 | 08:55 PM
ku7484's Avatar
Thhat SAMCO hose you have coming from the I/C to the BOV, where exactly did you get that!! It makes it look 10x better.. BRAVO on the job!
Old Apr 22, 2004 | 09:02 PM
Grod101's Avatar
most vendors have that rad hose upper and lower... hit adam up at www.z1auto.com
tell jerry from evo-ny sent you he will hook you right up... super good vendor also...
Old Apr 23, 2004 | 01:21 AM
mr96gsx408's Avatar
Congrats, it looks nice...
but some of your info is flawed... those pipes will increase horsepower so insignificantly you probably won't even notice it... bigger pipes = more volume to fill therefore it should make turbo lag even more... or cause worse pressure drop... haha
a gain would be that it's lighter, and bigger pipes allow cooler air to stay cool longer...
for those that say 1-5 hp is a big deal on a dyno.. you're mistaken... 1-5 hp variance can be affected by tons of things... you can probably gain 5 extra hp by having a lower temperature or blowing more cold air into the engine/intake...
my 2c...
edit: that's why for those guys that buy grounding kits for 100 bux, i laugh at the fools...
Old Apr 23, 2004 | 01:22 AM
Grod101's Avatar
my 2c...
al has an upgraded turbo already... I don't think that would effect him....
