My lightweight battery set up - in the trunk
Old Jun 5, 2003 | 08:46 PM
Alfriedesq's Avatar
Its show and tell time - seriously - this sucker is 10 lbs lighter than the stock one
Attached Thumbnails My lightweight battery set up - in the trunk-battery.jpg
Old Jun 5, 2003 | 08:58 PM
jfh's Avatar
jfh
How about some additional install details, e.g. wire routing, AWG size, remote disconnect, etc...? Any more pics to show how it is positioned in the trunk? Is it a custom fab battery box or off-the-shelf piece?
Thanks
Old Jun 5, 2003 | 09:01 PM
mrdecibel's Avatar
How much does the box weigh?
Old Jun 5, 2003 | 09:11 PM
Alfriedesq's Avatar
Its the summit racing polish alum box - its not too heavy - it has a seled cover with two flip locks
I have 1/0 monster power cable running up to a monster junction box you can see in the attached pic - I have two giant monster fuse blocks in the battery box
This mod really helped the handling - espacially after i did the flex!
Old Jun 5, 2003 | 09:12 PM
Alfriedesq's Avatar
Fuse block
Attached Thumbnails My lightweight battery set up - in the trunk-rmrfmic4.jpg
Old Jun 5, 2003 | 09:14 PM
import_speedzz's Avatar
Yeah?.. Can you show us how you did it?... COz therez alot of people who want to do that..
Old Jun 5, 2003 | 09:58 PM
Tarmac Black's Avatar
so by the time it was done you didnt really lose any weight. you just moved it. the wire and the box would make up the weight savings. not trying to bash ya but why did you put it in the trunk? just curious.
Old Jun 5, 2003 | 11:26 PM
Alfriedesq's Avatar
It handles better with the 35 lbs weight removed off the front axel and some of that moved to the rear
Old Jun 6, 2003 | 12:41 AM
Infinity's Avatar
Isn't there a lot more resistance in the wiring due to moving it in the back, it wasn't meant to be in the back so much of the amp flow might not have been calculated properly.
Old Jun 6, 2003 | 12:46 AM
superz's Avatar
nice work, although 1 guage is way overkill. 4 guage is appropiate for the car. Also, only one 175 amp fuse is needed, why did you use 2?
Old Jun 6, 2003 | 12:52 AM
EvoRider36's Avatar
Hey Alfreidesq, you wouldnt happen to be the silver evo that ran 12's at englishtown last friday are you? If so, very nicely done.
Old Jun 6, 2003 | 01:09 AM
Alfriedesq's Avatar
Yeah - that was me - to bad I happened to line up against a ringer who ran a .009 reaction time off the tree - my race night ended early but i got in some good times - - BTW - I may be headed back there tomorrrow night also
Old Jun 6, 2003 | 07:22 AM
neilschelly's Avatar
Probably insignificant resistance at best. Wires tend to be pretty low resistance (that's why they're used for wiring and all), especially 1gauge....
-N
Old Jun 6, 2003 | 11:12 AM
EvoRider36's Avatar
Yea, I knew that was you. I should have said whats up. Oh well, I wish I was headed down there tonight, but I have work. Hopefully ill be able to make a trip up on wednesday. You should see if you can meet up with Incognito's red evo down there, he has also made some impressive low 12's passes that ive seen. Very impressive showings from the both of you. I'd love to see you guys run each other, it would be interesting. Anyways, if you go tonight, good luck.
