Oxygen Sensor Simulator
Old Jun 6, 2003 | 01:48 PM
MalibuJack's Avatar
As many of us are aware.. Some of the exhaust systems available right now (with an offroad pipe) will trigger a Check Engine light because the rear O2 sensor is not responding appropriately. I found a GM OBD-II Sensor simulator on this site:
http://www.fasttoys.net/grandprixexhaust.html
The only issue I have with this is if its Wire compatible.. Basically the rear 02 sensor only needs to oscillate a voltage slightly but to maintain a particular voltage on average, and it won't throw a CEL.. If it maintained a steady "Optimum" value, it would throw an error because it would think there's something wrong.
and a project circuit if someone wants to run with it..
http://www.bobblick.com/techref/proj...sim/o2sim.html
Which is supposed to be adjustable.
Hope this helps you techies out there who choose to eliminate a Cat for racing..
Old Dec 2, 2004 | 09:58 PM
Ztypestock8's Avatar
ok, so how do i buy one from this site? is there a home page to this site?
