Suggestions on a quality, slighty louder than stock BOV?
Old Dec 2, 2004 | 08:40 PM
Bobby12many's Avatar
There are so many out there, that when I search I get like 1000 pages
Suggestions for a louder than stock recirculation valve?
Old Dec 2, 2004 | 09:08 PM
smp3000's Avatar
Go JDM!!! Buy the MR valve. It's cheaper than most out there- is aluminum and works great.
Old Dec 2, 2004 | 09:13 PM
EVIL MR's Avatar
he want louder
Old Dec 2, 2004 | 09:16 PM
smp3000's Avatar
yup- and it is a little. The piston is a bit stiffer which I think causes for a harsher let off. If it's not that then it's the fact that the air isn't housed in plastic but aluminum. Just sounds better IMO.
But whatever you do don't go FORGE. I heard the APR (I think that's it) is really good.
bo0oost's Avatar
GReddy Type S?
Old Dec 2, 2004 | 09:17 PM
BuLocal's Avatar
Aps
Old Dec 2, 2004 | 09:21 PM
kimletrim's Avatar
Registered User
Greddy Type S recirculated will definitely get you a little louder. All you will hear is a little wimpish psst. And no idle problems with the smaller spring removed.
Now if you want to step up to the plate and have the Types S, VTA, then you will definately be louder with shifts above 3000 rpm, but you will actually be quiter below that point.
Old Dec 2, 2004 | 09:23 PM
mitsuorder's Avatar
I run a MR diverter valve, it's a little louder than stock. I have heard that the APS valve is pretty good along with the bov offered from Works.
Jakeg97's Avatar
greddy type s
Old Dec 2, 2004 | 09:25 PM
feldguy's Avatar
The air filter is the key to hearing the BOV more pronounced. Change the air filter and get a Turbo XS recirc, put two washers in it and it'll be perfect. It flutters a little than lowe throttle let offs at cruising speeds are harsh-sometimes, but otherwise, smooth as glass and high PSI holding power. No leaks!
Old Dec 2, 2004 | 09:41 PM
eve-slow's Avatar
Whats wrong with the Forge?
Old Dec 2, 2004 | 09:55 PM
smp3000's Avatar
not saying all forge priducts are bad- sorry if I came off that way. But I had really bad luck witht he FORGE DV. It looks really cool- and seems to be a good product- but unless you're running stock intake I wouldn't recomend it.
I had some surge running stock intake, and then once I installed the perrin short ram it would surge no matter what RPM or gear I shifted in. After trying all the different springs in the kit I gave up- sold it- and got the MR.
Old Dec 2, 2004 | 10:00 PM
TheSmacker's Avatar
GFB....if you want it louder/quieter just VTA more/less.
http://www.lancershop.com/customer/p...&cat=27&page=1
KeganP
Apr 23, 2012 01:08 AM
UD Kingo
Mar 10, 2010 03:37 PM
nala
18
Feb 11, 2009 07:31 PM
ridenrunwv
May 3, 2008 10:27 PM
evosr2bnvd
41
Apr 17, 2007 04:42 PM
