Urgent Neeeeeddd Help Please!!!!
Background.....car runs and pulls hard and strong, I install an amp and sub in the car and go take the car for a ride and as soon as the car starts to spool to full boost around 3,300 RPM/ 12 lbs of boost the whole car sputters/shakes/brick wall effect. I can't describe it other than sputtering ALOT. The car idles fine, drives and pulls fine until 3,300 RPM.
1) No codes are being thrown
2) All the fuses are fine, none were blown out
3) Going to check the spark plugs now....not sure if that would have anything to do with it.
As far as the car, it has a forge unos MBC, Turbo back exhaust, Injen intake...and was flashed by TT when the previous owner had the car. I also check all the vacum lines as well and they are all fine.
This car has never done anything like this before and i can't seem to figure out what the problem is or what to do for that matter. Any help or advice would be greatly appreciated.
Thanks,
-Ray
Thanks,
-Ray
Yea it just doesn't make sense to me....like i said i was driving fine all morning, do the install (have done plenty before) go for a drive and it's messed up, undo what i did and the same thing occurs
Do you still have the stock airbox. If so did you pop out the push plugs holding the scoop?
That scoop can lift if not held down and choke airflow.(Has happened to quite a few on here)
^^^ I almost agree with the fuel idea....although why would it drive and idle fine?
I am going to run outside and re-check the hoses and such....thanks for all the replies and suggestions thus far guys I appreciate it.
