innovate wideband prolem help
Old Mar 28, 2007 | 10:25 PM
EvoDan2004's Avatar
Originally Posted by Jeff_Jeske
Try it in a different vehicle to see if the readings change .... if it does the same thing in another car then the unit is dicked up.
well installing it into another car is way pointless. i already put a new sensor on the lc-1. so it must be somthing after the sensor. nice to know i spend 350+ on somthing that lasted a year. i hope innovate helps me fix this problem or relaces something if its bad.
350.00 for lc-1 and xd 16
80.00 for new sensor
joy - priceless
Old Mar 28, 2007 | 10:32 PM
Dapper Dan's Avatar
Originally Posted by evodan2004
and there is 0 exhaust leaks. i check'd and re trq'd everything from the manifold to the test pipe. also recal'd the damn sensor again. and yet again nothing. next
how exactly did you check for leaks? you cant just look and see the leaks just FYI.....
Old Mar 28, 2007 | 10:35 PM
EvoDan2004's Avatar
yes and no. 1st i looked. then i started the car and again looked. i used my hands to feel for a leak. then i used a 1/2 hose and put one end to my ear and the other on each part that can have a leak. i did not here anything. then i retorqed everything and did it again to make sure. and again. nothing.
Old Mar 29, 2007 | 12:28 AM
EvoDan2004's Avatar
anyone else with idea?
Old Mar 29, 2007 | 05:53 AM
sbiggi's Avatar
Check with a laptop what it is reading.
My roommates XD gauge freaks out every now and then
If you use logworks on the laptop, the laptop was showing the correct A/F.
Old Mar 29, 2007 | 09:34 AM
klatinn's Avatar
Hi,
Check with LM Programmer what fuel type is programmed in the LC-1. Often that is the problem if people plug and unplug the LC-1/XD-1 while under power.
Regards,
Klaus
Old Mar 31, 2007 | 02:21 PM
kreionic's Avatar
The wideband readings in evodans car is the same on the xd-16 as it is in evoscan and logworks. So its not the gauge freaking out. He is putting in another persons car today to see if its with the lc1 itself or his car.
Old Mar 31, 2007 | 06:46 PM
Evol.ved's Avatar
You shouldn't pay more then 55 dollars for the sensor. It's off of an 03 V-dub turbo motor.
Did you do a full heater calibration.
Old Apr 2, 2007 | 10:01 AM
klatinn's Avatar
Hi,
A simple check if exhaust leaks cause false readings at idle is to simply push a towel against the tailpipe. Don't push too hard, you don't want to stall the engine. Just enough to create positive pressure in the exhaust system. This positive pressure will prevent exh. leaks to pull in outside air. If your WB readings change significantly when you create pressure, you have a leak.
Regards,
Klaus
Old Apr 2, 2007 | 10:49 AM
scottatyamaha's Avatar
Also if you have a busted headgasket and started burning coolant it will make your wideband read whack also. Just one more thing to check for.
