innovate wideband prolem help
Old Mar 28, 2007 | 07:36 PM
EvoDan2004's Avatar
ok i have the innovate lc-1 and xd-16. my reading just went from normal at idle to 25.1 ish. when i wot the car it is reading 18.whatever. so what i did was i recalibrated it and still nothing. same crap. i called innovate and they said maby the sensor is shot. so i replaced it. and again recalibrated it and still all messed up. anyone have any idea wtf is going on?
Old Mar 28, 2007 | 07:40 PM
4WS Tuning's Avatar
ur pulling it out of the down pipe when u recal right?
did it ever work right?
did u follow all the instructions... u cant ground couple of the wires together or it does throw the readings off for some reason..
Old Mar 28, 2007 | 07:42 PM
EvoDan2004's Avatar
it has ben installed for over a year. it worked fine up untill now.
yes i pulled it out of the downpipe.
i even left it out when i put the new sensor on.
Old Mar 28, 2007 | 07:43 PM
yesevo's Avatar
mine is reading 14.7 at idle....is it perfect ? tuned by dynoflash~
Old Mar 28, 2007 | 07:45 PM
4WS Tuning's Avatar
with crap like that....
i would take everything out and just start from scratch....
too much stuff integrated to guess where the problem is..
sorry i couldnt help
good luck
Old Mar 28, 2007 | 07:47 PM
EvoDan2004's Avatar
i hate my life. i haver had nothing but problems for the past 3 weeks. now i can add my wideband crapping out on me to the list
Old Mar 28, 2007 | 08:23 PM
EvoDan2004's Avatar
ok well all conections seem'd to be fine. i dont know what to do now.
Old Mar 28, 2007 | 09:09 PM
EvoDan2004's Avatar
anyone have and other idea's?
Old Mar 28, 2007 | 09:22 PM
Jeff_Jeske's Avatar
Possible exhaust leak prior to the sensor.
Old Mar 28, 2007 | 09:36 PM
EvoDan2004's Avatar
i dont here one. but i will go look. i will brb.
Old Mar 28, 2007 | 09:37 PM
Jeff_Jeske's Avatar
It doesn't take much to throw off that sensor. If your downpipe is loose or your O2 housing is leaking those numbers will go south very quickly.
You may want to double check your grounds as well.
Old Mar 28, 2007 | 09:40 PM
EvoDan2004's Avatar
i already check'd and reground'd everything. conections and install is perfect.
Old Mar 28, 2007 | 09:42 PM
Dapper Dan's Avatar
my friend had the same problem...his o2 housing was leaking....
Old Mar 28, 2007 | 10:09 PM
EvoDan2004's Avatar
and there is 0 exhaust leaks. i check'd and re trq'd everything from the manifold to the test pipe. also recal'd the damn sensor again. and yet again nothing. next
Old Mar 28, 2007 | 10:11 PM
Jeff_Jeske's Avatar
Try it in a different vehicle to see if the readings change .... if it does the same thing in another car then the unit is dicked up.
