Just talked to RMR
Old Jun 10, 2003 | 01:16 PM
Obsoleteasian's Avatar
hmmm what is his standpoint on other parts than his, with t he ecu reflash.. i talked to vishnu and he said that even with other parts and his xede, that i would expect similar gains.
Old Jun 10, 2003 | 01:27 PM
zx6r's Avatar
Is this reflash, a reflash like they upload the data via some upgrade port ?
Or is it where they remove the EPROM / Flash device from the ECU board, solder a socket on and reprogram the EPROM / Flash in a EPROM programmer ?
Old Jun 10, 2003 | 01:30 PM
evo1's Avatar
Call RMR
Old Jun 10, 2003 | 01:38 PM
evo1's Avatar
Sorry to chime in but ALL of these ECU reflash set-ups, piggybacks, etc ... should be compatable with other parts ... a 3" turbo back is BASICALLY a 3" turbo back, regardless if it's Vishnu, RMR, or Thermal ... and there isn't much other little stuff to tune for besides ... bigger cams (HKS 272), larger throttle body, etc. So unless you start to get craz-e ... changing turbo's, etc ... you won't have to worry about this. It is NOT mandetory or EXTRA BENEFICIAL to stay with one manufactuer/tuner for all of your needs .... other than that of convenience .... no way RMR WILL ONLY tune for its own products ... since competing products perform the same function. This is the qaurrel I have with WORKS ... since they are pushing Exhale and the rest of the products at people by claiming that theit ECU reflash "may or may not" be compatable with other products ... BS MAN! A mufflerless exhaust ... don't think so! That thing WILL BE LOUD AS HELL!
Old Jun 10, 2003 | 05:42 PM
N10S's Avatar
Sounds like another great ECU tuning solution!
Man I really wish there were some tuners in the midwest or the east that were involved in this kind of tuning solution. Not that west coast tuners are bad, but RMR, Vishnu, and Works all seem to fall back to the safety net of tuning for 91 octane fuel.I think Vishnu will do a high octane map if you are local and spend time on the dyno. Some of Shivs past comments confirm how much better the car runs with 93-94 octane, and how much more detonation prone the car is running 91 octane.
Anyway, I am truly glad that there are more choices, but really am bummed that everyone gets to pay the penalty for California's crappy gas.
BTW- These comments aren't meant as a slap at Ca EVO owners. I know you guys don't have any choice in the matter, and are stuck with what you can get.
Old Jun 10, 2003 | 07:52 PM
RMRBlair's Avatar
I wish I could answer everyone’s questions, but please give us a call if anyone has questions. I do not want info floating around that is misleading good or bad. Here are a few answers to some of the info above.
-The ECU is made with our intake, down pipe, and exhaust. Other companies’ products will probably work similar.
-The first car Dynode made 225hp, with an intake and down pipe it made 253hp and with the ECU, Intake and down pipe it made 278hp. with stock cat & exhaust...
- The ECU is a flash only reprogram. It does not require the computer to be opened up and soldered.
-The ECU does much more than what a boost and AF controller can do.
Can a boost and AF controller adjust for atmosphere?
Can a boost and AF controller adjust ignition timing?
Does the boost and AF controller have safety restrictions to save your engine?
There are a lot of good uses for those controllers, but the factory ECU can do much more.
-The ECU can adjust boost up to 1.3 bar (19.11psi) anything beyond that a boost controller is need to bring it higher, BUT the ECU has all the parameters for fuel and ignition up to 1.8bar if you wanted. (Defiantly not recommended for stock engines)
Basically what you are getting it is a save - reliable car that halls *** and you don't have to screw around with levels or worry about over boosting or leaning out too much. The car will hit 1.3bar and hold it though the power band. It is also great for cars looking for more serious power (350- ???). It’s a great base to start off of for a lot of other piggy backs and other controllers.
Please give us a call if you have any questions. We did not expect the info to get out so quickly, I will not be able to get the info up on our site for a little while.
Old Jun 10, 2003 | 08:02 PM
nynguah's Avatar
Come on now Blair - you guys release an inexpensive (relatively speaking) chip from a reputable tuner located in the middle of the import craze that runs safely on 91 fuel and you didn't think the info would get out quickly?
-Josh
Old Jun 10, 2003 | 09:24 PM
SARS chip
Old Jun 11, 2003 | 09:33 AM
evo1's Avatar
SARS chip
And that is???
Old Jun 11, 2003 | 10:03 AM
evo1's Avatar
Originally posted by N10S
Not that west coast tuners are bad, but RMR, Vishnu, and Works all seem to fall back to the safety net of tuning for 91 octane fuel. Bummed that everyone gets to pay the penalty for California's crappy gas.
In regard to the RMR reflash for 91 octane, it shouldn't be a huge difference in power for users that are running 93 octane. If the reflash is set up to maximize potential while running as safe as possible on 91 octane, then it just means that users running higher octane gas WILL NOT be running at full potential ... yet they will be running an even safer set-up. But my point is that 2-3 octane difference should NOT translate into a huge power difference ... maybe 5-10hp? ... just a guess as far as the actual # 's but I wouldn't be so sure that this will be such a big deal. Don't forgret that our ECU is also self learning so there are many parameters that the brain will learn and adjust to on its own ... that's the beauty of running a reflashed or replacement ECU set-up opposed to a piggyback in most cases. I personally am really leaning toward this set-up ... seems like a much smarter & more practical way to go compared to Xede or GReddy EManage ... unless one enjoys constant tweaking with the EManage (EManage CANNOT adjust to atmosphere and other conditions on its own)!, or plans to really mod like craz-e and would rather not pay to have the computer reflashed over and over ... but then again, since the ECU is self learning, only major mod upgrades will call for a reflash.
Old Jun 11, 2003 | 10:10 AM
Originally posted by evo1
And that is???
the issue happening in china, if i can remember...
(a joke)
Old Jun 11, 2003 | 10:21 AM
evo1's Avatar
(a joke)
Ehhhhhh ... okay, got it ... thanx bud.
Old Jun 11, 2003 | 12:09 PM
shiv@vishnu's Avatar
[QUOTE]Originally posted by evo1
As far as we've been able to tell, there is nothing self learning about the factory EVO ECU besides mild knock retard learning. We have not been able to isolate any long term fuel open loop learning or coarse/fine knock correction maps. It is very much unlike the Subaru WRX ECU and, therefore, has its own share of drawbacks and strengths.
The Emanage, or any other piggy-back, doesn't need to as the underlying stock computer is still actively handling the factory temp and altitude compensations. Unless you want to change the compensation variables (which is unlikely), there is no compromise in this repsect.
Whatever learning ability exists in a reflashed ECU still exists in a stock ECU/piggy-back combo.
They're are theoretical advantages to reflashed ECUs over piggy-backs, but they have yet to be mentioned. These include raising of the rev limiter, moving of map table rpm/load breakpoints. There are also theoretical advantages to good piggy-backs over reflashed ECUs. This incluces realtime maps switching, user programability, additional fuel/timing transient enrichments, 3D boost control, etc,. The actual relative pros and cons will depend upon application and mapping characteristics, of course.
Just my 2c,
Shiv
Old Jun 12, 2003 | 08:35 AM
Jonasan50's Avatar
Damn, my head hurts...!
Old Jun 12, 2003 | 09:19 AM
wizardofoz's Avatar
Your lucky, mine just exploded
