Clutch adjastment. Help
Is there a way to adjust the clutch after install? And if there is where is it. The clutch is Exedy twin plate. Was fine after install but after the test drive it does not disengage fully. The clutch pedal does not get stuck or anything. There is tension on the pedal.
ThanX
ThanX
yeah right behind the pedal is a lock nut and a set screw...
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=28
that has pics and everything.. good luck ,
and how do you like the clutch? how is it for everyday driving?
For the few miles I drove the car it felt perty close to stock. It just is noisy. If it is going to stay like this than I am happy. I just hope to get it up and running.
