wide band o2 question?
Subscribe
Apr 11, 2007 | 04:08 PM
when installing a the aem wideband o2 gauge and sensor is it as simple as swapping out the o2 sensors and plugging up the gauge, or is there some ecu tuning that needs to be done, right now im on stock ecu. Can i just get a little feed back on the installation of one of these bad boys
Reply 0
Apr 11, 2007 | 04:11 PM
No tuning needs to be done. Its a monitoring device thats all.. I am not sure how the install of the AEM is though. sorry. Every wideband I have used I needed to weld another bung for the wideband sensor
Reply 0
Apr 11, 2007 | 04:12 PM
I'm pretty sure you have to have a bung put on your exhaust for the wideband.
Reply 0
Here is the UEGO gauge manual. You can find the manual for the controller on the site as well.
Reply 0
Beat me to it.
Reply 0
Apr 11, 2007 | 04:14 PM
Quote: I'm pretty sure you have to have a bung put on your exhaust for the wideband.
You can put the bung on your DP, but you can use the stock O2 location.
Reply 0
Apr 11, 2007 | 04:20 PM
does it replace the stock o2 sensor and if not u mean that i will have 3 o2 sensors, the rear the front and the gauge sensor?
Reply 0
Apr 11, 2007 | 04:27 PM
Quote: does it replace the stock o2 sensor and if not u mean that i will have 3 o2 sensors, the rear the front and the gauge sensor?
If you take off your DP and have the bung wleded on it, then yes you will have three O2 sensors. Two narrowband and one wideband.
Reply 0
Apr 11, 2007 | 04:32 PM
Here is a post with pics to give you a better understanding of the install. This isnt the AEM install but it is basically the same thing.
https://www.evolutionm.net/forums/sh...deband+install
Reply 0
Apr 11, 2007 | 04:35 PM
it does not replace a current sensor, you must get a bung welded and install it... preferred place is before the cat on your DP. + there is a grommet there to run the wires.
Reply 0
Subscribe
