electrical problem HELP gauge clutser
Old Apr 17, 2007 | 06:57 PM
EvoDan2004's Avatar
ok seems when i turn my lights on my gauge cluster lights go out.. when i turn my lights off everything gets bright again. my radio and clock are doing it too. i cant seems to figure out why. i look'd at the fuses under the stearing colum but they lookd fine. any ideas what is going on?? thanks
Old Apr 17, 2007 | 07:25 PM
EvoDan2004's Avatar
anyone??
Old Apr 17, 2007 | 07:29 PM
krish's Avatar
First thing came to mind was maybe a dimmer switch turned all the way down/off. Never seen the "newer" Evo's to know if they have that feature, but I know some cars will blank out the dash lights when the dimmer is turned down, but couldn't say if that is the case for you. Just a thought...Good luck getting it sorted out
Old Apr 17, 2007 | 07:33 PM
EvoDan2004's Avatar
dimmer dont work at all. it used to when everything was fine. but i guess since my problem started it wont work till its fix'd again. thanks though
Old Apr 17, 2007 | 07:40 PM
gsrboi80's Avatar
Hey Dan Sounds like it might be the start to the water getting in by the drivers side foot well and getting on the plugs at the junction box and corroding pins.
1. Take off the drivers kick panel by your left foot.
2. There is a few White and A Black connector
3. Unplug the connectors 1 by 1. Do you see any greenish substance?
4. Put your hand on the back side of the connectors and follow the harrnes to where it goes though the inner fender well. Dp you feel any water?
If so there is you problem. I can help you fix it I did mine
Old Apr 17, 2007 | 07:44 PM
EvoDan2004's Avatar
ok let ysa know bro. hows you btw?
Old Apr 17, 2007 | 07:49 PM
krish's Avatar
Bummer...Well, good luck with it!
Old Apr 17, 2007 | 07:50 PM
gsrboi80's Avatar
Im good man. Yea take a look and let me know. Ill help you fix it if thats the problem. Its an easy fix just time consuming
Old Apr 17, 2007 | 08:05 PM
DanJ's Avatar
I have a feeling it has something to do with your dimming switch. Not directly but maybe follow the dimming switch and see if the wires aren't corroded and such.
Old Apr 18, 2007 | 01:38 PM
ninja808's Avatar
Did you have anything installed recently? I've heard of people having issues like this after recently installing any kind of new electronics in their vehicles and tapping into the wrong wires. Just a thought..
