Optima Mini Battery
Old Apr 17, 2007 | 07:28 PM
The Senator's Avatar
Optima Mini Battery
I've been doing a lot of reading and seaching about the mini battery kits. I really like Buschur Racing's mini battery mounting kit. Does anyone have any info about the specs of their battery (CCA, amp hours, and dimensions). The reason being is that I want to use an Optima Red Top battery, if compatible and a mini battery kit that mounts the same way as the Buschur Racing's battery kit. Here is the link to all of Optima's batteries http://www.1st-optima-batteries.com/ for their specs.
Hope someone can help out. Thanks.
Old Apr 18, 2007 | 03:33 AM
BillAce's Avatar
I,m using the Optima Group 51 Honda deep cycle battery. I made a sealed and vented aluminum box for the trunk and ran 1/0 awg wire. I would recomend the yellow top because with the smaller battery you are more likely to run it down and it will recover better than the red top.
Old Apr 18, 2007 | 07:46 AM
mudduck's Avatar
I wouldn't consider the Optima series to fall under the mini-battery category. Optima batteries weigh as much as stock or more, depending on their output specs. They most likely will not be able to be mounted sideways, either.
I have an Optima Red Top in my Eclipse, but it is used for running a high end car audio system.
The mini-battery kits used on Evo's are made to accomplish 2 main goals:
1) Weight savings (mini-batt's weight from 11-14lbs; compared to stock 35-37lbs)
2) Make room in engine bay, mostly to run the shortest UICP possible...
Hope this helps...
Old Apr 18, 2007 | 07:52 AM
mudduck's Avatar
^^^ forgot to add the most commly used mini-batterys for our Evos are:
Odyssey PC680 (I believe this is what Buschur sells) and PC680mj (metal jacket encased for high temperatures) - ??? CCA
Braille Lightweight (11.5lbs with 360 CCA) - stock CCA is 520; these get the job done, though...
Deka ETX14 (generic version of Braille - less $$- same battery, different sticker)
Old Apr 18, 2007 | 03:37 PM
Thanks for you help mudduck. I was thinking about the Braille CF mini battery kit but its a little too much just for a CF battery. After careful consideration, I think that I'm going to go with either the Nisei or Buschur mini battery kit.
Old Apr 18, 2007 | 03:40 PM
JohnBradley's Avatar
Another option is the Deka AGM for a Miata. Its what I use and weighs about 17lbs less than stock.
Old Apr 18, 2007 | 04:10 PM
Got a link or any info on it? Thanks.
Old Apr 18, 2007 | 06:39 PM
BillAce's Avatar
optima makes many battery sizes. The Group 51 is much smaller than stock and remember that the size relates to the output.
Old Apr 18, 2007 | 06:42 PM
http://www.eastpenn-deka.com/
pic of it in my car:
Old Apr 18, 2007 | 06:46 PM
AF-Evo8's Avatar
here's the specs for the odyssey, one of the best as far as output power.
http://www.odysseybatteries.com/battery/pc680.htm
Old Apr 18, 2007 | 07:06 PM
Exciting News's Avatar
^What UICP is that? Looks like the Deka, while smaller, doesn't allow for UICPs that require a small battery. Then again, maybe it just looks that way.
Old Apr 18, 2007 | 07:07 PM
Thanks but I want to go with a kit that has the battery facing or mounted toward the fender.
What piping kit is that you have installed?
Old Apr 18, 2007 | 07:10 PM
Just the kind of specs I was looking for. Thanks.
Old Apr 18, 2007 | 07:36 PM
That battery can be mounted anyway you would like, I did this by myself and was too lazy to run longer battery cables (which a "storebought" kit would provide). There is actually a fair amount of room between the pipe (That one is a Trust/Greddy) and the battery.
Old Apr 19, 2007 | 06:23 AM
mudduck's Avatar
Not quite - the engine bay pic on this thread is running a Deka AGM (fits a Miata?); there is a smaller, lighter version (Deka ETX14) that is the generic version of the Braille lightweight for our cars - these only weigh like 11lbs, so you are looking at around a 25lb savings...
