loud vibrating noise from rear? (im stumped)
Old Apr 21, 2007 | 12:32 PM
cfdfireman1's Avatar
Get in
Originally Posted by SLVR_Bullet
ok i had a buddy drive and i took out my rear seat so i could hear it better....it sounds like a panel vibrating very loud like if you had subs in your trunk.....still cant figure out the exact spot its comming from but its definatley in the trunk
the trunk. Bring a flashlight with but it sounds like an exhaust pipe hitting somewhere to me.
Old Apr 21, 2007 | 12:39 PM
Dapper Dan's Avatar
its definatley not the exhaust....it sounds like i have subs but without the bass lol...
Old Apr 21, 2007 | 03:23 PM
Check your dif mounts and all the bushings in the rear as well.
Old Apr 21, 2007 | 10:38 PM
barneyb's Avatar
Try driving with the rear windows down. My car does this too. It is aerodynamic buffeting. I think some of those roof spikes might help. Maybe this is the real reason Mitsu designed them.
Old Apr 21, 2007 | 11:33 PM
Dapper Dan's Avatar
if that was the case t would have been doing this all along, but it just started doing this......and i already have a vortex generator.
Old Apr 22, 2007 | 10:30 AM
barneyb's Avatar
Well, I noticed my car doing this several years ago. Since then nothing has gone out or failed and it hasn't gotten any worse.
At least try what I suggested, try driving at the speed where you encounter this with the rear windows at some position(s) besides closed. If the sound is much louder inside the car (and I mean a lot louder - like you can feel it) then I think you will see what I mean. Otherwise, I am wrong.
Old Apr 22, 2007 | 10:48 AM
revvin9k's Avatar
As dumb as it may sound, try rebalancing your wheels. I balanced my six months ago and had the same issues as you. Took em to work and rebalanced them. The drivers front was off 1oz total, and the drivers rear 1.25oz total.
They were zeroed when I did it six months ago. Just a thought and cheap fix.
Old Apr 22, 2007 | 04:55 PM
curisu's Avatar
My personal experience is that the center rear panel was the culprit. It was vibrating against a piece of sheet metal in one place, against the cross-bars in another. To fix it, I velcro'd some closed-cell foam pieces at the touch points.
You can confirm this by removing that panel and hitting your target speed. Mine was loose enough that by lightly tapping different areas of the panel, I could reproduce the sound.
Old Apr 22, 2007 | 08:43 PM
Dapper Dan's Avatar
thanks for all the tips guys...im gonna take all my panels out tuesday so im sure ill find the problem then
Old Apr 23, 2007 | 11:01 AM
FiftyFive's Avatar
Sounds like wheels bearings. I had a same vibrating issue every other second or so. Took it to the dealer, they replaced it and it went away.
Old Sep 25, 2008 | 05:01 AM
MichalD's Avatar
Hi all
Sorry to reply in such an old topic, but I have an exact same issue like Dapper Dan - strange noise (vibrations) from rear end over 90 mph in my 06 MR.
It doesn't sound like rear differential, more likely something with aerodynamics (mayby roof antenna gets vibrations? or vortex?)
Any new ideas in this case?
Hope this is not differential...
Car has 34k miles.
Regards,
Michael
Old Sep 25, 2008 | 05:10 AM
SOEuro's Avatar
did you ever find it Nick?
Old Sep 25, 2008 | 08:00 AM
ejanusie's Avatar
sure it cant be your fuel pump>
Old Sep 25, 2008 | 08:04 AM
MR Turco's Avatar
My heatshield hits my HFC at higher speeds. Could it be that? It sounds similar to what you describe.
Old Sep 25, 2008 | 11:07 PM
bso's Avatar
bso
Check the gas tank cover panels under the car. I found one was missing a nut that holds it in place and the funny thing is that the shaft where the nut threads in still has paint on it untouched from the factory. Monday Evo!
