What LSD Additive brands are out there?
Old Apr 23, 2007 | 07:42 AM
BBYBruno's Avatar
Well I want to mix 1.5 ounces of LSD Additive in my rear diff but I keep searching and can't find any brands, can someone help out? Thanks.
Old Apr 23, 2007 | 07:55 AM
BBYBruno's Avatar
Bump
Old Apr 23, 2007 | 08:05 AM
BBYBruno's Avatar
Nevermind got it.
Red Line Friction Modifier and Break-In Additives
Smooth operation for your clucth-type limited slips.
Red Line differential friction modifier and break-in additives can be added to any gear oil to replace the manufacturer's limited-slip additives. They are ideal to tune a limited-slip unit.
Old Apr 23, 2007 | 08:29 PM
CO_VR4's Avatar
Mitsubishi has its own factory friction modifier available. I assume you already knew that.
Old Apr 23, 2007 | 10:36 PM
barneyb's Avatar
You don't need to add anything unless you are having a problem with the diff. By a problem I mean chattering or a loud snap sound when turning.
Old Apr 24, 2007 | 05:06 AM
BBYBruno's Avatar
I know. You get that when you put Heavy Shock Proof in the rear diff, so AMS advised me to add 1.5 ounces of friction-modifier.
Old Apr 24, 2007 | 07:19 AM
barneyb's Avatar
Pardon, you need it.
Just so others know, friction modifier is really friction reducer. What you would be doing if you WERE NOT having problems is reducing the LSD action.
