Check this EVO
Old Apr 24, 2007 | 12:49 PM
augosta's Avatar
Check this EVO
Track evo9
Can't believe that when I first purchased the evo I had no intention of touching a screw!
It only took a few weeks of itching until modification virus took over. An exhaust here & a gauge there surely was going to be enough
How I was wrong! This thing turned from stock to I don't know what
Ok here it is. After six months work with the help of many this is was I have:
Engine
3 inch exhst catbck (amuse titanium); down pipe + test pipe (hks)
k&n air filter & alloy divider plate
blow off valve (hks)
ecu (motec m800 plug & play); wide-band o2 (lambda) sensor; motec boost cont. solenoid + connect; 2 position switch ecu
radiator (koyo); radiator cooling plate (cusco); radiator cap cp9a, ct9a (sard); radiator pipe (samco); alum. radiator pipe shield (b. whls)
intercooler (hks type r); intercooler ducting
turbo kit (hks garret 30 37s)
external fuel pump + plumbing kit; performance inlet manifold; throttle body 80 mm; fuel rail (ams); 1000 cc injector set (hks); fuel regulator (sard)
spark plugs (hks)
cylinder head studs(arp)
oil catch can; modify oil system + large oil pan
2.3 stroker kit with requirements (aat)
cyl.head + block modification/honing
thermostat 71deg. C
engine dampener (sard)
tuning (motec) 2 maps
Handling & Drive-train
race suspension (zeal - function)
f+r stainless brake line kit (endless); frnt racing disc rtrs crss drld (endless); rear rotors basic (endless); racing pads (endless); brake duct cooling kit (ams)
twin carbon clutch (exedy)
limited slip dif. frnt type rs (cusco); limited slip dif. rear type rs (cusco)
bump steer correction kit (whiteline); front steering correc. Kit (whiteline); roll center adjust kit (whiteline)
rear triangle os-t (cusco); rear brace (cusco); front strut bar triangle bar (cusco)
anti-sway bar frnt 25mm (cusco); anti-sway bar rear 23mm (cusco); sway bar links frnt & rear (whiteline)
lower arm bar ver. 1 (cusco); lower arm bar ver. 2 (cusco)
vortex generator; front c. fiber spoiler lip (apr); gt3 c. fiber side mirrors (apr); gtc c. fiber wing (apr)
slick tires (hoosiers) 255; wheels (volk rays) 18 – 9.5
Controls & safety
race bucket seats (sparco corsa); seat brackets + slider (sparco)
steering wheel (sparco 383); quick release bolt in (sparco); steering boss (sparco)
4+2 harness (sparco)
floor mount alum. (sparco)
4 gauges + controller (Defi); gauge holder (front pillar); turbo timer (apexi); rev. limit indicator (defi)
ignition kill; fire extinguisher system (lifeline2000); roll-cage (cusco)
Interior accessories
carpet (Lancer stock); dashboard + center console paint (red); foot pedals (sparco); gear knob (sparco); oil cap (hks); center console (gauges)
[IMG][IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG][/IMG]
Old Apr 24, 2007 | 12:51 PM
Sap12687's Avatar
Just post the pictures in here. I don't think anyone is going to want to register.
Old Apr 24, 2007 | 01:04 PM
augosta's Avatar
Old Apr 24, 2007 | 01:09 PM
ddddddana's Avatar
nothing showing up on my end
Old Apr 24, 2007 | 01:10 PM
lexat20's Avatar
nada
Old Apr 24, 2007 | 01:13 PM
Blue By You Evo's Avatar
because u still have to login. save the pics to your comp and re-host them to imageshack.us or photobucket or somethin
Old Apr 24, 2007 | 01:14 PM
nofear's Avatar
Old Apr 24, 2007 | 01:15 PM
Warrtalon's Avatar
The pics don't work, because they are probably on that site in a restricted area. You need to download them, then attach them or host them on photobucket and link to them.
Old Apr 24, 2007 | 01:16 PM
EvoEntropy's Avatar
pics
Old Apr 24, 2007 | 01:41 PM
05blackevo8's Avatar
no pics
Old Apr 24, 2007 | 01:44 PM
SteelEvo's Avatar
i can't see X|X..but i understand the virus ive had my car only 2 months lol...and i put all this crap on it..LOL
Old Apr 24, 2007 | 01:46 PM
Rod Munch's Avatar
Well, it sounds nice anyway.
Originally Posted by augosta
engine dampener
You mean damper, don't you? Or does it wet your engine for you?
Old Apr 24, 2007 | 01:47 PM
turbochrgdbeast's Avatar
pics still not working.
Old Apr 24, 2007 | 01:50 PM
Jax419's Avatar
Old Apr 24, 2007 | 02:07 PM
Redline06's Avatar
Damn what kind of work do you do for a living to afford all of that..??? Also how much did that whole set up cost you over there.. i see alot of you guys use motec on the EVO.. must be a nice car.. so get them pics working dude..
