View Poll Results: Stock IX MR Gauges - Accurate/Not Accurate
The Stock IX MR Gauges ARE Accurate
30
78.95%
The Stock IX MR Gauges ARE NOT Accurate
21.05%
Voters: 38. You may not vote on this poll
Are the Stock MR Gauges Accurate?
Old Apr 30, 2007 | 01:23 PM
Rich EVO MR SE's Avatar
Are the MR Gauges Accurate? Do they generally read high, low, or on the money?
I mostly want to confirm the Boost Gauge accuracy. Has anyone done a comparison test of any sort?
Old Apr 30, 2007 | 01:24 PM
hksevoix's Avatar
I run 2, seems accurate to me
Old Apr 30, 2007 | 01:26 PM
kreionic's Avatar
throw your car on a dyno have them log boost and see then. That the only way your going to get your answer
Old Apr 30, 2007 | 01:27 PM
bvdawg13's Avatar
its dead on accurate i do believe
Old Apr 30, 2007 | 01:29 PM
Yeah Thanks I could've told you that, has anyone tested them on a dyno?
Old Apr 30, 2007 | 01:30 PM
Warrtalon's Avatar
Mine was accurate at sea level as expected.
Old Apr 30, 2007 | 01:37 PM
spdrcr456's Avatar
with the engine off mine sits a little below 0. when it should be at 0. i have a 05
Old Apr 30, 2007 | 04:42 PM
Nuked's Avatar
mine was pretty close to the autometer which was about 1psi lower than the dyno. of course I peg the stock gauge.
SQ
Old Apr 30, 2007 | 04:45 PM
fromWRXtoEVO's Avatar
Based on my experience dynoing the car in various dynos and meassuring the boost with the dyno test probes and also with my additional Defi BF imperial electronic gauge I find the MR gauges accurate.
Also the voltmeter is accuarte, I verified it with an APEI turbo timer which comes with a built in digital voltmeter.
Definately yes, accurate.
Carlos
Old Apr 30, 2007 | 05:14 PM
mrfred's Avatar
I've done boost logging in EvoScan using the JDM Evo 9 MAP sensor. My observation of the MR boost gauge during the logging runs compares well with my boost data from the logs. So, I'd say its accurate to within 1 psi. I don't think the oil temperature measurement system is terribly accurate though. I don't think its the temperature gauge so much as it is the crappy location of the oil temperature sensor. Don't know about the voltage.
Old Apr 30, 2007 | 05:18 PM
I don't think its the temperature gauge so much as it is the crappy location of the oil temperature sensor. Don't know about the voltage.[/quote]
Uhmm... I am curious, where do you think is a good place to put the sensor then? Having the sensor on the botton of the oil pan is a location in which the oil is undisturbed.
Carlos
Old Apr 30, 2007 | 05:20 PM
Ultimate CC's Avatar
its all relative for the most part anyway, its just a tool used for tuning and monitoring...
Old Apr 30, 2007 | 05:42 PM
mrfred's Avatar
Carlos
The problem is that the sensor is not in intimate contact with the oil. The sensor itself sits loose inside the drain plug. Makes for a poor thermal path between the oil and the sensor. Pulling the pan and welding in a bung for a thread-in sensor would go a long ways towards more accurate oil temperature measurement.
Old Apr 30, 2007 | 05:51 PM
mrfred's Avatar
Using a sandwich oil cooler adapter with a temperature sensor port would be another option.
Old May 1, 2007 | 08:12 PM
I'll probably end up sticking with my stock gauges then. I'm not too worried about the oil temp being as accurate as the boost gauge. I usually wait until the oil temp gets to about 70 degrees celcius before I boost or go WOT.
