Name That Decel Noise! (PLEASE)
Old May 2, 2007 | 07:19 PM
monies41's Avatar
I have recently noticed some strange decel noise. I had done numerous things including a clutch install this last winter. All fluids were replaced with factory DiaQueen fluids. It only does it on decel. My clutch is a Exedy twin HD on a 6 sp MR tranny. It goes away on decel when i push in the clutch and does not happen when i take it out of gear. You can hear it better if you turn your bass down
http://s108.photobucket.com/albums/n...cture050-1.flv
Old May 2, 2007 | 07:20 PM
bmguser's Avatar
sounds like t-case?
Old May 2, 2007 | 07:30 PM
XK120's Avatar
hm could be t-case...do you have enough power to support that kind of clutch?
Old May 2, 2007 | 07:31 PM
DeiPro's Avatar
Sounds like it is the clutch upon decel. I just had a customer car last week that had an Exedy HD Twin that made that noise on decel and cruise, deffinitly bad in my customers case, but yours does not sound as severe, and I have heard that it is common on decel for this clutch.
But its hard to tell exactly from the video.
Kyle Deiwert
President
DeiPro Tuning
Old May 2, 2007 | 07:33 PM
mack4477's Avatar
he's running a 50 trim, so he has the power for the clutch. in fact, i have about 70 horse less and don't hear that kind of noise on the same clutch
Old May 2, 2007 | 07:35 PM
monies41's Avatar
Kyle Deiwert
President
DeiPro Tuning
so you think it could just be the clutch? Did he have a 6 sp or 5
Old May 2, 2007 | 07:38 PM
AhmadHasib's Avatar
bump for answers
Old May 2, 2007 | 08:25 PM
drift_Fan's Avatar
My moms evo does the same thing when its decelerating, its started right after she had the works clutch installed.( yes my mom has an evo and shes 39, and im stuck with an es, go figure. sorry about going OT)
Old May 2, 2007 | 08:29 PM
XK120's Avatar
Sorry to go OT but your mom has an Evo?!?! That's sweet
Old May 2, 2007 | 08:30 PM
evolsk8r's Avatar
It's the clutch. I also have the exedy twin in my MR, and it makes the same noise.
Old May 2, 2007 | 08:34 PM
j-evo8's Avatar
its the clutch. I had the Exedy Twin and it made alot of noise on decel. Just put in an ACT single plate and the noise is all gone.
Old May 2, 2007 | 08:43 PM
Dayton_EVO's Avatar
I have a ACT HD with a Pro-Street lightweight flywheel and mine does the same thing. I think this is somewhat normal with an aftermarket clutch. From all the threads I have read through over the last couple of years, they all say(or most say) if it was the Transfer case, the noise would be somewhat constant regardless of how you drive(if I'm correct). Also, if it is only on decel it could be a transmission issue as well. Mine does this if I Decel in 4th gear (while letting off the throttle.) If I hit the gas it will go away. Have someone who knows Evo's drivetrains very well take a ride in it and see what they have to say, if you can find anyone close.
Later
Old May 3, 2007 | 08:40 AM
joah1660's Avatar
It's cool that a chick has an Evo...But even better when it's a Mom!!!
Old May 3, 2007 | 08:48 AM
Xraycat's Avatar
Its nice to hear that its a common noise, I thought for sure something was wrong with my clutch. I had an ACT clutch put in a couple months ago and I didnt notice the noise till a few weeks ago. (I really need to turn my stereo down )
Old May 3, 2007 | 08:53 AM
Mad_SB's Avatar
Sounds like the TC, like the beginings of the death whine. Twins normally make more of a rattling than a whining. If the whining gets to the point that it is loud then you need to call shep and get a new tc.
My twin disk makes a nice rattle, on top of that I have the old decel noise. I Installed the twindisk at the same time I replaced my Tc. All three are distinct noises.
Decel noise is a tough to describe rattle, Twin disk is a more obvious rattle. TC on it's way out is a siren like whine or howel when on light to no throttle.
Drain your tc and look for shavings.
