IC PIPE Blowing Off, now CEL???
Old May 3, 2007 | 11:58 PM
  #31
chrismnj's Avatar
Originally Posted by Cali2MDevo8
Disconnect your battery and see if you throw another CEL
Jason
u should never disconnect your battery befor geting the code
Old May 4, 2007 | 12:16 AM
  #32
SOEuro's Avatar
this has been happening to me alot latley,WTF is causing it,im only on 20 psi
Old May 5, 2007 | 06:29 AM
  #33
Silver06evo9mr's Avatar
Originally Posted by EVOllie
Are ur plugs giving u any problems?? or you just worried you fouled them cause u drove a lil bit with the pipe off?
If ur cars got a hick up or spit at idle, crusin, or wide open then change them.
If they were cheap copper plugs, id change them for a piece of mind.
And what A/F are you talking about? idle or wide open?
plugs are fine, but its time to change them anyways. and im talkin about both WOT and idle. idle is when i noticed it more though seems to be running way lean
Old May 5, 2007 | 06:54 AM
  #34
Bash's Avatar
Man up and get some t bolt clamps
Old May 5, 2007 | 08:24 AM
  #35
EV0lved's Avatar
Originally Posted by Silver06evo9mr
ok your done. its the UICP that connects to the throttle body
i know a few ppl that have had this happen to their evos...myself as well...last night, so go to NAPA ask for a 3 inch t-bolt clamp, it will never come off again
Old May 5, 2007 | 06:14 PM
  #36
^^ yea i know that i am, but i was just wondering about the CEL
Old May 10, 2007 | 05:41 PM
  #37
my CEL came back on again even ater they cleared it. still saying its a cat convertor code. goin in tues to get somethin fixed. im guessing my O2 sensor is f-or somethin i dunno
Old May 11, 2007 | 11:19 PM
  #38
bump
Old May 12, 2007 | 01:51 PM
  #39
Zmann42087's Avatar
...and A/F ratios are normal even though my a/f guage says other wise.
Do have a wideband or narrowband O2 gauge? If its a narrowband, don't even bother looking at it. Those blinky-light-show Air/Fuel gauges don't tell you crap.
Old May 15, 2007 | 01:29 PM
  #40
ok well got my car back form dealer long story short.... they found my ecu flash, they said my cat is "melting down" and i need a new one, and surprise surprise my warrenty is now completely gone id say it was a good day
time for an upgrade TBE
Old May 15, 2007 | 02:04 PM
  #41
sonicnofadz's Avatar
Absolutely hilarious.
Old May 15, 2007 | 03:35 PM
  #42
glad some one thinks it funny
Old May 15, 2007 | 03:48 PM
  #43
You should of flashed it back to stock before you took it in, but the warranty is a joke anyways. They tend not to honor the warranty regardless if you are stock or not, so you might as well modify the hell out of it now!
Old May 15, 2007 | 03:50 PM
  #44
already begun ^^
Old May 15, 2007 | 03:55 PM
  #45
Evo9"Miss Rose"'s Avatar
Originally Posted by mudduck
bro, a screwdriver doesn't cut it for tightening up an IC pipe that keep blowing off.
Go home, get your ratchet/socket set out and tighten all of the worm clamps up real good and you will be done with it...
You don't need to run out and get T-bolt clamps unless you are running some serious boost on meth or race gas...
use T-bolt clamps regardless if your at stock boost or not...its always a for sure answer that those stock hoses that flex under boost will not pop off if it has t-bolt clamps on them!!
