IC PIPE Blowing Off, now CEL???
I know its a problem that everyone has had, well now its the second time for me. Only this time it happened on a major highway so i had to drive about 2 miles stopping every few hundred feet to keep putting the pipe back on becasue i didnt have a damn screw driver, then when it popped off one time the clamp disapeared on the road. So i had to drive a little ways to get to a part store to get a clamp and a screw driver.
Well after i finally got another clamp i got it back together and got back on the highway. Well after about 20 more miles it went off again. So i stopped fixed it, then when i started the car again the CEL was on. What does this mean?? Im guessing the plugs are fuct. Someone help me out what should i do??
yea i thought of that, but the first time it happened i know the dealer towed my car cuz i didnt know what it was, and my mechanic said he cleaned my plugs. will they get f'ed up if i drive without the pipe on?
its dark now will try doin the battery thing 2mmorow
they will foul quickly. I have an OBDII scanner and can clear your codes if you need it.
bro, a screwdriver doesn't cut it for tightening up an IC pipe that keep blowing off.
Go home, get your ratchet/socket set out and tighten all of the worm clamps up real good and you will be done with it...
You don't need to run out and get T-bolt clamps unless you are running some serious boost on meth or race gas...
damn plugs aint cheep haha, ijust had to buy a 4k t-case because mitsu sucks *** and some one broke out my window last night along with 20 other cars in my neighborhood which cost me 50 plus 42 for new tint, so i dont need to spend any more $$ right now
um, okay... I was honestly only trying to help...
I have had the UICP pipe blow off at the TB many times on the highway; to the point where now I actually keep a small ratchet with the correct-size socket in my car, just in case.
which got cancelled cause it rained but oh well guess ill try again next wednesday night lol
