Cel
Old May 3, 2007 | 05:15 AM
20lbsboost's Avatar
Cel
hey guys,
i need to pass inspection and i took off my DP and test pipe yesterday and threw on stock cat n DP with my RNR catback. There are 2 minor leaks because the gaskets broke when my friend used them for his inspection. I tried the 02 fix with the non foulers and i still threw the 02 sensor code. Now after reseting my ecu and teh stock cat i still have the CEL. Would 2 minor leaks cause this or is my 02 sensor dead at 40k miles?
thanks
Old May 3, 2007 | 05:17 AM
EvoFlash's Avatar
This is a good question I will be doing the same thing...
Old May 3, 2007 | 06:01 AM
yikez's Avatar
read the code first ..
Old May 3, 2007 | 06:07 AM
20lbsboost's Avatar
P0141 EGO Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
Old May 3, 2007 | 07:31 AM
20lbsboost's Avatar
never used race gas either..
Old May 3, 2007 | 10:41 AM
sonicnofadz's Avatar
Reset ECU, if that doesn't work, replace your O2 sensors.
Old May 3, 2007 | 11:50 AM
20lbsboost's Avatar
thats the weird part..when i reset my ecu i can drive with no CEL until i turn the car back on..then it just stays on
Old May 3, 2007 | 11:52 AM
bluebyu36's Avatar
dam i know a bunch of people on long island that would pass your car no matter what.
Old May 3, 2007 | 12:41 PM
20lbsboost's Avatar
LI cant do it because im registerd in NJ right?
Old May 3, 2007 | 07:13 PM
bluebyu36's Avatar
i dont no but i dont see why not it's an inspection sticker....
Old May 3, 2007 | 07:18 PM
wizzo 8's Avatar
If you hit the o2 sensor too hard on accident like dropping it or it gets too much vibration it will go bad. Maybe this is what happend
Old May 3, 2007 | 07:29 PM
dragstr05's Avatar
Thats because on some vehicles a specific monitor may require (2) or more key cycles to go through a specific monitor. Most mitsubishi's arent this way, but I've had a couple that were.
PO141 - Your O2 is probably bad, or you broke it. Replace the O2.
EDIT: Do yourself a favor and double check the connector. I just remembered thats the one that tucks up inside the body, and they really dont leave much room to work with, let alone slack in the wires. If all wires and connector is good, pick up an O2.
