Experience with mitsu service dept.
What is considered normal wear and tear is clutch disc facings and is not covered under warranty. What is covered under warranty are: the transaxle case and all internal parts, gasket, and seals; transmission case and all internal parts, gaskets, and seals; transfer case and all internal parts, gaskets, and seals; torque converter (including ring gear); transaxle, transmission and transfer case mounts.
drag strip
well this is my first manual transmission car, so it took awhile to get used to it, and yes i launch alot. I race on weekends at the drag strip....
second thing....vesendak, im not lazy...the box clearly says will not void warranty...which means you can leave it in, jackass!
hey guyss.. i burned my clutch at 3000 miles.. i had a K&N filter BR cat back..took it to da dealer, i didnt say a word about the cat back.. they did see da intake.. n asked me y i changed it i said coz it LOOKED GOOD.. tats all they asked got a free clutch in 2 days time.. i dont see y u shuldnt get 1 but change it back to stock.. go to a dif dealer they ll change it.. but if ur planing on doing stuff to it get a better clutch coz i got re tuned after a week wit br stage 1 went to da drag strip after 600 mile break in.. n burned it in 10 pases.. some ppl say they still run da stock clutch wit da cams on.. yes u can as long as u dont lonch da car it ll hold.. im on my 3rd clutch so maybe u wanner think 2ce about putting da stock clutch.. da IX s r crazy when it comes to torque..
Your clutch wont be covered because of it being considered a wear item, welcome to evo world where you pay to play, but as far as him telling you ,
"you have no warranty" he is full of s^it and is talking out his ***.
Magnusson-Moss warranty act.
US Code - Title 15, Chapter 50, Sections 2301-2312
Legally, a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson Moss Warranty Act (15 U.S.C. 2302(C)) .
thats such an ignorant comment, he said he was new to driving a manual and he tracks it on the weekends.
anyways...that sucks man, i can't believe (well yeah i can) they voided your warranty for that..
Well if your warranty is voided it will be because of the drag racing not the filter. It's possible that your clutch was defective from the factory but not likely. My guess is once they take the trany off and inspect the clutch and flywheel they'll be able to tell. If the flywheel is scorched and or the disk is cooked. Then that would lean toward bad or aggressive driving.
I still don't see y so many people drag race this car so much. It is a much better autocross and road race car.
Stock the IX car runs 12.9 to 13.3 if you can drive. If you can't get those numbers then your launch needs pratice but when you pratice you could end up with a spent clutch in no time.
If you're concerned about your warranty then it would be advised that you keep your car as close to stock as possible.
Good Luck
Good Luck
Your post count is probably just going to get reset when an admin sees this. Oh and hint, hint, they will
thanks to that nice little red button in the corner
