Trying to install 6 speed shifter bushings
Old May 11, 2007 | 09:10 AM
Zoxygen's Avatar
Well I'm trying to install Speed source underhood shifter bushings for my MR.
I've found where the smaller bushing goes (right on top in plain sight) but where dues the second larger bushing go?
Thanks!
Old May 11, 2007 | 09:14 AM
Evoryder's Avatar
down 2 the left..what a itch to install lol
Old May 11, 2007 | 09:17 AM
Zoxygen's Avatar
Alright I think i see it...looks impossible lol
Anyone have suggestion on how to get it?
Old May 11, 2007 | 12:41 PM
Zoxygen's Avatar
booo, no help?
Old May 11, 2007 | 12:44 PM
ambystom01's Avatar
Take out the intake system?
Old May 11, 2007 | 12:46 PM
Evoryder's Avatar
oh...take out the intake, i think you need to remove battery... lube forearms and get ready for the cuts...u can get it out, needle nose pliers or strong construction finger tips...
Old May 11, 2007 | 01:06 PM
Zoxygen's Avatar
Well it still seems impossible lol I have the battery IC pipes intake and brackets out (im installing other things also)
Am I looking at the right thing? Is the pin facing the firewall?
Old May 11, 2007 | 02:13 PM
Evoryder's Avatar
this is for the 5spd i believe, install is very similar
http://www.joe250.com/cars/evo/shiftlinkagebushings.htm
Old May 11, 2007 | 02:29 PM
Chemwarrior's Avatar
I just had to remove the battery to get to both bushing sites. Remove the pin and then use your fingers to remove it. It requires some finger strength, but with some patience you can get it.
Old May 11, 2007 | 04:09 PM
Dr.Sound's Avatar
make sure to take the battery tray out as well
Old May 11, 2007 | 04:13 PM
I didn't have to remove mine, just the battery.
Old May 12, 2007 | 05:02 AM
turb0z-MR's Avatar
This is good stuff, I need to put my bushings in SOON.
Are you using anti-seize with your bushings or are you just going to install them?
Old May 12, 2007 | 05:14 AM
Jakeg97's Avatar
i am just going to install them
Old May 12, 2007 | 07:39 AM
It took me literally less than 30 minutes to install them. It's just that easy.
Old May 12, 2007 | 08:04 AM
smarsenal's Avatar
Putting in the bigger bushing is a real "knuckle buster"!!
IMP!! Be sure NOT to accidentally kink the clutch line when you are working with the lower shifter bushing.
