Need your imput before i spend all my money
Old May 15, 2007 | 11:01 AM
fitbikedominick's Avatar
Ive listed my current set up on my evo 9 along with the new parts i plan to buy at the end of the week. I want to know what you guys think regarding the parts and also how much power you think i will put down on 93 octaine, no alk or meth injection. I am also trying to figure out about how much boost i will be able to safely run on the new set up (i think i could go up to 23psi and be safe) Im getting my car ready for a evo green turbo hopefully to be put in by july.
Current mods-Buschur 3 inch down pipe
-Buschur high flow cat
-Bushur 3inch cat back
-Bushur MAF cone filter
-MBC at 21psi
-Mail in Flash by Al
made 307whp 304ft lbs
Ordering at the end of the week when i get paid
-Buschur upper intercooler pipe
-Buschur Delux intercooler and lower intercooler pipe
-Bushur Tubular o2 housing
-GSC S1 cams
-GSC valve springs with cromo retainers
-ARP headstuds
Old May 15, 2007 | 11:13 AM
mrich82's Avatar
I'm planning on basically the same stuff. Do you have a fuel pump yet? If not, then add that to the list for sure. I was also going to do a ported/coated exhaust manifold... see if Buschur recommends that since that is the majority of your parts.
Old May 15, 2007 | 11:18 AM
vortech_g35's Avatar
I believe you don't need the springs and retainers on your current setup. You would need a Fuel Pump, maybe a mini battery kit, and you should be good after that. With the stuff your gonna add which would gain power are just the cams & FMIC, probably 330-350 whp. That cat is killing you.
Old May 15, 2007 | 11:19 AM
Sluggo's Avatar
yea, id recommend getting a pump also, and if you have a good tuner locally id go for a custom tune after you install your cams and ditch the mail in.
sonicnofadz's Avatar
You will probably be in the 360-385 whp range (dynojet) depending on who tunes it. I recommend Jestr
Old May 15, 2007 | 11:32 AM
yeah i have a 255 welbro already that i forgot to list. I was planing on doing some sort of turbo manifold but i dont have the money at the moment to do it. I am also on the fence weather to run a tubular turbo manifold or run a ported stock
Old May 15, 2007 | 11:36 AM
I would really like to run a test pipe i just dont want my car to be too loud under normal driving. I bet with the cams and new front mount set up my car would gain alot from a test pipe
Old May 15, 2007 | 11:37 AM
anhhi's Avatar
Porting+Coating the stock manifold would add a few more ponies.
Old May 15, 2007 | 11:47 AM
TeStUdO's Avatar
You would make at least 15-20 whp by running the test pipe as opposed to the cat with your new mods and tune.
Old May 15, 2007 | 11:53 AM
sixfatbabies's Avatar
DONT GET AN O2 housing.. complete waste of money. doesnt do anything unless you have a bigger turbo. and even then it still isnt worth the money
Old May 15, 2007 | 12:04 PM
4G63Rules's Avatar
Are you serious?
Old May 15, 2007 | 02:45 PM
LITE SPD's Avatar
I doubt it. On the dyno he is on he made just over 300hp-300tq with basic bolt-ons. Unless he runs race gas or meth will he won't see those #s on the same dyno. I will give him a max of 30hp and 30tq over what he has with those mods on the same dyno.
And I understand you want to do the I/C, bolts, and pump for the future prospect of adding a green turbo, but I'd leave those out till you actually get the turbo. Horsepower/torque or the prospect of running safer shouldn't change with or without those items till the bigger turbo is in.
BTW, leave the o2 housing out of it also. The housing will make power but not enough to justify going in twice for labor whether you do it yerself or not.
Old May 15, 2007 | 02:52 PM
evobeatsti's Avatar
my friend with an evo ix with the same mods as you but with the green and without the cams and with a test pipe made 312whp and 288lbft on a mustang tuned and at 24 psi
Old May 15, 2007 | 02:53 PM
evobeatsti's Avatar
i think you should make at least 330whp with the mods you have listed, get rid of the cat and pick up an extra 15 or so whp and port your stock mani for $150 from buschur and pick up another 10ish whp
Old May 15, 2007 | 02:54 PM
evobeatsti's Avatar
plus one last thing i forgot to add, with the buschur uicp you will need to run a mini battery kit, and i hope you get the pipe and retain your stock bov, i got the buschur pipe with the forge valve and it was the biggest piece of crap ever... good luck
