engine question
Old May 16, 2007 | 12:06 PM
jenx1976's Avatar
engine question
this is not evo related but can somebody explain to me ( without being too technical ) what makes a engine rev high as in a ferrari V8 compared to a regular amerciacn V8?
Old May 16, 2007 | 12:09 PM
sabastian458's Avatar
The displacement. Ferrari v8's are tiny, americans are big.
Old May 16, 2007 | 12:30 PM
hondafan's Avatar
yep, makes for shorter stroke so you can run more rpm's without having your piston speed going into the danger zone.
Old May 16, 2007 | 01:30 PM
Kerr's Avatar
Fomer Vendor
Yes, your engine could very well be on the highway to the danger zone.
Old May 16, 2007 | 02:21 PM
jenx1976's Avatar
cool...thanks!
Old May 16, 2007 | 02:24 PM
4g63tFan@tic's Avatar
Low displacement and balanced internals
Old May 16, 2007 | 02:46 PM
antij0sh's Avatar
Lets not forget lighter rotating mass inside the engine (pistons, connnecting rods, crankshaft, etc.) , less of a force when each part stops and changes direction.
Old May 16, 2007 | 03:15 PM
hondafan's Avatar
it's more a matter of piston speed due to the stroke than lightweight internals. even with the lightest internals, you can only have so much piston speed before you run into issues. most domestic V8's use a long stroke, high displacement motor that would encounter reliability isssues running higher rpms due to the piston speeds encountered. for example, in indy V8's, which we all know rev to the moon, they use a very short stroke and a large bore to get the displacement of the motor to accomplish this.
