Sunroof Headliner Removal?
Old May 19, 2007 | 12:58 PM
XK120's Avatar
Question Sunroof Headliner Removal?
For those of you that have removed your sunroof headliner (part that slides over the glass), how did you get the piece off? I've removed my entire headliner but I can't seem to figure out how you remove the sliding sunroof piece...anybody have some suggestions?
Thanks
Old May 19, 2007 | 02:52 PM
XK120's Avatar
anybody?
Old May 19, 2007 | 05:37 PM
Dennis F's Avatar
You have to take the glass out first. Then there should be a couple clips holding the shade in from the top.
Old May 19, 2007 | 07:40 PM
XK120's Avatar
Sounds complicated...is it easy to take the glass out?
Old May 19, 2007 | 09:01 PM
Dennis F's Avatar
Shouldn't be to bad. I have not taken one out of an Evo yet.
Just vent the glass open to the top, there should be 6 screws of adjustment, 3 on each side. There may be a plastic cover to hide them, havent looked yet.
Take those screws out from inside the car, then ump out and remove the glass carefully.
You should see a couple tabs on each side to remove the shade. This is exactly how it is set up on Webasto, Harada and a few other brands of roofs.
Old May 19, 2007 | 09:13 PM
XK120's Avatar
Thanks Dennis! I'll try this first thing in the morning
Old May 21, 2007 | 01:23 PM
XK120's Avatar
Bump...I've got the glass out but still can't seem to get the headliner out.
Old Sep 15, 2007 | 06:59 AM
KFizzle's Avatar
Hello, what ever happened with your sunroof headliner removal???? I have to take mine out because I burnt a hole in it smoking !@#$
Old Sep 15, 2007 | 07:40 AM
XK120's Avatar
Wow it's been a while...I basically just bent down the back metal part then pulled as hard as I could until it came out...it worked, but now the headliner makes a pretty bad noise everytime I open/close it haha
Old Sep 15, 2007 | 06:05 PM
KFizzle's Avatar
Thanks for the info I will keep that in mind. I just hope It will not leak after I mess with It. Did you have any issues with ajustment or anything like that.? Thx again
Old Sep 15, 2007 | 06:19 PM
holler mcdollar's Avatar
can i ask why you would want to get rid of it..? unless of course it's effed up from smoking like that guy^
on really sunny days i still find myself closing the shade because it's bright even with the window tinted.
Old Oct 11, 2007 | 07:14 PM
EvoKnievo's Avatar
i think it was so he could re upolster it? i would also like to know how to remove this
Old Oct 11, 2007 | 07:37 PM
Kirbyryu's Avatar
I would also like to know as I am looking to re-upholster mine also.
Old Aug 28, 2008 | 10:11 AM
ModifiedOne's Avatar
Ditto
Old Apr 16, 2009 | 10:45 PM
daisaw1219's Avatar
bump does anybody know how to remove the sunshadE?
