aem wideband install
ok i've search for an hour and havent found what im looking for maybe im not using the right terms.
my question is where does the sensor get installed? (weld into the 02 housing or does it get welded into the exhaust pipe somewhere..
I believe it goes by the cat(or where it should be)...works nice if you have both a cat back AND a DP with o2 bungs already built in...this way you dont have to get a bung welded on or anything. Im lookin foward to puttin one on i just have to take the o2 plug out should be nice.
Will get mine next week, can't i just use the stock narrow band location, since i am running an o2 sim instead of it already?
My autronic ecu doesn't use the stock one, too...
Think i should be ok with this, right?
Regards,
Mike.
Regards,
Mike.
Do NOT install it in the o2 housing. The wideband sensor is more sensitive and it will burn out being that close to the turbo. Right before the cat/test pipe is a good place for it, or in the testpipe.
Thanks!
