Put tanabe exhaust on now i have check engen light
Old Jun 1, 2007 | 01:42 PM
wickedwhiteIX's Avatar
Exclamation Put tanabe exhaust on now i have check engine light
i got the turbo back exhaust and removed the cat i think the check engine light is from the o2 sencer is there any way i can fix the light problem?
Old Jun 1, 2007 | 01:44 PM
dudical26's Avatar
come on you can find the answer to this with about 5 min of searching.
You have a bunch of options, you can turn the CEL of using ECU Flash
In my opnion the best way to do it is use spark plug non foulers. Search that and you will dinf your answer.
Old Jun 1, 2007 | 01:45 PM
brokeazzlos's Avatar
no ****, you have no cat!
Old Jun 1, 2007 | 01:46 PM
Kay@kacework.com's Avatar
/ban
Old Jun 1, 2007 | 02:13 PM
esevo's Avatar
1st search for it, so you dont get flamed. 2nd the spark plug non foulers trick is an easy fix. Just go to autozone pick up the 18mm spark plug non foulers, ($4.00) drill out one so your o2 will screw in then install... if you search you can get pics and all the info with pics good luck fng!!!
Old Jun 1, 2007 | 02:54 PM
prj.evo's Avatar
spark plug anti-foulers are the way to go. $3 for 2 at autozone.
Old Jun 1, 2007 | 02:57 PM
Daniel_4g63's Avatar
anti-foulers
Old Jun 1, 2007 | 06:42 PM
mech88's Avatar
Get a cel fix..
Old Jun 1, 2007 | 06:43 PM
BluEVOIX's Avatar
How loud is yor combo compared to stock? WOT, idle, and normal driving (both in cabin and outside)?
Old Jun 1, 2007 | 06:50 PM
BretTheJet26's Avatar
i have a question... i took my engine out of my car, and now it wont run? why?!?!?!
Old Jun 1, 2007 | 10:23 PM
lemmonhead's Avatar
dont worry ECUFLASH can fix that to, car runs great without an engine. +1 for ECUFLASH
Old Jun 1, 2007 | 11:05 PM
Zmann42087's Avatar
Does your new Tanabe exhaust have the needed bungs for all the O2 sensors? If it doesn't and you left an O2 sensor out/unplugged, that is surely why your throwing a CEL. To fix the problem all you need to do is get an O2 simulator.
Old Jun 1, 2007 | 11:41 PM
chrismnj's Avatar
that is 100% normal
Old Jun 2, 2007 | 12:53 AM
MRQ06's Avatar
I got the same exhaust (concept G blue) with the test pipe and I just did this https://www.evolutionm.net/forums/sh...d.php?t=114931
Good Luck
Old Jun 2, 2007 | 12:55 AM
Kdash106's Avatar
great choice on the exhaust.
