Boost leak.....need quick help
Old Jun 6, 2007 | 07:51 AM
PorkRoll's Avatar
Exclamation Boost leak.....need quick help
I made a boost leak test and im trying to perform the test right now. Ive pumped quit a bit of air in to the test already, but there is no pressure yet. How long do i have to pump air for to get to 20 psi+/- ?
Old Jun 6, 2007 | 07:55 AM
bvdawg13's Avatar
should be instintaneously....you must have one bad leak or something isnt hooked up right with your test
Old Jun 6, 2007 | 07:57 AM
matt55's Avatar
what works best for me is
1 is to have #1@tdc
2 have a warmed up motor
3 have alot of air ive tried to use a 3gal tank and thats not enuf
Old Jun 6, 2007 | 08:08 AM
PorkRoll's Avatar
Here is the problem i am having. https://www.evolutionm.net/forums/sh...d.php?t=275119
I made the tester, put it on the turbo where the intake would go. Im using a 50 gallon compressor so i have a constant air supply. This morning i saw 19 psi @ WOT. Ive pumped alot of air in.....NOTHING HAPPENS
Old Jun 6, 2007 | 08:54 AM
matt55's Avatar
Did you try TDC on a warmed up motor ?
If you did and its still not working take off the IC hose from the TB and plug it (The bottom of a spray paint can works for me with a hose clamp , but it could get messy if the can pops off .... So i tape the can down , getto but it works)
Now your boost gauge in the will not read any boost and the BOV will leak so it needs to be removed and the hose pluged .
I have a valve stim on my tester and use a tire gauge to test psi
And i have a IX BOV so i just flip it around and it holds psi while testing.
Old Jun 6, 2007 | 12:33 PM
HEAD DYNAMICS's Avatar
I've been down this road before and it ended up being a stuck EGR valve. Listen for any air coming out of the exhaust.
Old Jun 6, 2007 | 01:01 PM
PorkRoll's Avatar
MATT55. I tried what you suggested. It worked. Not with a a spray can though. It ended up being a blown gasket inbetween the turbo and the LICP. No one with in 3 hours has the gasket though so i put a thermostat gasket to get me home
