NEED HELP ASAP Downpipe Install!
Old Jun 8, 2007 | 06:38 PM
80210's Avatar
I'm trying to throw on my DP and its getting dark! I cant get the piece that screws the front end of the dp into the 02 housing to budge!
any tips or what did you do?
I've tried using PB Blaster, Hammers to hit wrench, wrenches, CANT GET IT
Old Jun 8, 2007 | 06:40 PM
bigric09's Avatar
try tightening it a little bit and then loosen it
or a torque bar, or something to let you put more torque on it
Old Jun 8, 2007 | 06:42 PM
80210's Avatar
someone said you need a foot long extension? true?
scottatyamaha's Avatar
Try to heat it up some with a torch.
Old Jun 8, 2007 | 06:44 PM
bigric09's Avatar
as long as you can reach the bolt extensions dont matter... i normally use a ft long though or the 8 inch, whatever it takes... a torque bar will be your best friend though... as long as you dont break the bolt off in the housing
idriveanevo's Avatar
it helps... the springs are what make it really hard. try the long extension
Old Jun 8, 2007 | 06:45 PM
bomjoon's Avatar
should have worked out more before... lol
dont force it too much you dont want the bolt breaking on you.
try an impact gun if you have one.
yours is a new car so it should come off pretty easily.
Old Jun 8, 2007 | 08:02 PM
2006MRevo's Avatar
Get some PB Blaster. Spray it on the O2 bolts from the top of the engine. Start the car and let it warm up enough to evaporate the PB. Spray some more on, then shut the car off. Let the car cool down enough to touch the exhaust and try removing the bolts. The PB soaks into the threads and loosens all that crap up to make it easy to break free.
Old Jun 8, 2007 | 08:11 PM
Thegame's Avatar
Yeah, I'm very surprised those spring bolts are giving you trouble. Now the bolts on the cat on the other hand... What I would do is just spray the living **** out of them with PB Blaster and let them sit overnight. Or get the biggest breaker bar you can find and add some length to it with a pipe. I use my floor jack handle for the added leverage.
Old Jun 8, 2007 | 08:13 PM
ziggity's Avatar
PB blaster and impact gun kicked their asses... just try it.
Old Jun 8, 2007 | 08:14 PM
Exciting News's Avatar
..and anti-seize upon reinstallation and avoid this issue in the future...
Old Jun 8, 2007 | 08:17 PM
mifesto's Avatar
also one hard impact w/ the wrench is better then slowly pulling/pushing on it... if u know wat i mean. maybe even get a hammer and bang on the wrench to break it free.
Old Jun 9, 2007 | 09:30 AM
80210's Avatar
Got them thanks!
Old Jun 9, 2007 | 10:14 AM
ntwaddel's Avatar
I soaked them with penetrating oil, then used the impact. Came off no prob.
Old Jun 9, 2007 | 02:03 PM
pulley1fan's Avatar
PENETRATING SPRAY!!!!!!!!!!!!!!!! Man I love that stuff.
