ACD Lights (all 3)
so I can drive it and nothing bad is going to happen? im going to take it to the dealer on fri but i just wanted to make sure in between if i drive it isnt going to damage anything. does anyone know what the dealer charges to bleed it? and from the scan will they be able to tell me if a sensor is bad or if a sensor is unplugged?
I had this same issue. I forgot to attach the MAF Sensor harness and all 3 lights came on. This was over a period of 3 months of me trying to diagnose the problem. The issue of the 3 lights coming on and staying on or sometimes it didn't come on was an easy fix. I went to the Mitsu Dealership and the technician reset the ACD error and issue was resolved. The technician was cool about it and wrote it up as a warranty fix.
when he wrote it up as a warranty fix was ur car modded? i have all bolts including air intake vta bov uicp and bigger frontmount, cams and its lowered haha.
but u had no porblems driving it? thanks so much this put my mind at peace while i try to figure this out.
I had this problem- It was because I had low brake light voltage.
i was running all LED's in all 3 taillights.
Switched it back to regular and the problem dissappeared.
Now I have LED's in the tails, and a regular bulb in the CHMSL
This happened to me as soon as I installed my AEM EMS and went speed density. My MAF plug is to this day uninstalled and I've been driving around with all three lit for quite some time. I will get in to the dealership to get it reset eventually
Tom
Tom
well Tom thanks for the battery and the new front mount both went on great except the battery change caused the acd lights which im stuck with right now.
For the guy who it was a couple fuse which ones where they? any help would be good
haha...they were the two that are the most difficult to remove...the ones surrounded by the yellow plastic casing...I tested them with a circuit tester without taking them out and they seemed fine...but I guess they really weren't according to mitsu dealer and 110 dollars later
hi guys
yesterday it happend to me driving from copenhagen across whole germany to austria,1400km like 1000 miles almost,,and like i started the car,after 6 min,all 3 lights solid,,then i just stopped turn off the engine,and went back on tarmac again...after couple mins the same happened,so i was driving and in the half of my trip when i was filling the tank,it just stayed normal till i arried,and it was like 700km,i dont know what is going on,and even one confusing thing happened when i was going like 200km/h just the check oil light turn on and just in a second turn off,what could it be?no idea?
thanks
thanks
