I was thinking....for the smaller time guys....
1. It is installed in the same location as the original
2. It is the same type as the original (i.e., two-way, three-way, three-way plus air/three-way plus oxidation)
3. It is the proper model for the vehicle application as determined and specified by the manufacturer
4. It is properly connected to any existing air injection components on the vehicle
5. It is installed with any other required converter for a particular application
6. It is accompanied by a warranty information card to be completed by the installer. These laws and federal guidelines are put into place for a reason.
more laws...
Scorke
more laws...
Scorke
Even if I were to go get it tested depending on the gas I was running I could get away with running no cat and still pass the test. I care because I think a test pipe is a simple mod that almost everybody does, and in order to make this sort of fun/full of competitors no cat is the best move.
also-
(Note that Federal law prohibits removal or replacement of a properly functioning O.E. converter).
If your going to be technical about legality of the cars according to DOT/Federal auto laws then this idea will fail because very few cars are entirely "legal". Removing your crash beam is illegal...
Scorke
ok im lost?is this like street racing?or who can get the best times within the rules?
and it will most likely be stock turbo guys,most guys with big dawg turbos run AEM.plus most stock turbo guys run meth to up the boost a bit.
well whatever you have in mind GL,seems like fun.wish i was on mainland side be good to watch.(i dont meet the requirements,haha)
