Innovative Db mounting
Well i just received my Innovative wideband, and i'm curious as to where all the other members mounted the DB gauge at? I'm thinking of getting rid of the little lancer sign in the cluster and putting the gauge there as well. I'm not sure if it will fit or not, but i've read the tutorial at the how to section. So what do you guys think? Also the lc-1 can still be hooked up elsewhere to be able to connect to my laptop right? Haha, i know its kind of a noob question but had to ask.
No if you hook up the DB gauge you CAN NOT LOG. The DB gauges connects to the analog out on the LC1 so theres no place for the serial cable anymore If you want a gauge and still log you need the XD 16
This is not correct. The DB gauge does connect to the analog output on the LC-1 that is correct. However, that still leaves the serial output of the LC-1 available to be plugged into a laptop and logged.
I have no issue at all admitting when I am wrong. If I am wrong about the DB gauge then I am wrong.
This is from Innovates website
"Note: The DB gauges have NO serial capability, and can only display AFR. For complete channel and color configurability, and for integrated remote-MTS button (calibrate, log start/stop), see the XD-16."
Again if I am wrong my apologies
